Transmission Abuse
Old 01-16-2007, 1:17 PM
Bike(s): '06 CBR1000RR/'06 919/'04 CRF450R
Rep: BadBrad is on a distinguished road (10)
Transmission Abuse
How much abuse can my 919's transmission take?
Here's the background:
I just switched to HP4 (50/50 synthetic oil) to make the shifts a little smoother and it definitely did. So much so that I accidently shifting while riding the other day and grinded the gears.
I was taking off from a light (in first) and had my foot under the shift lever applying a little 'pre-load' pressure but it actually went out of first through neutral, the engine revved up to about 5000rpm and then started grinding second gear before i could grab the clutch.
Everything seems to be normal but does anyone think that this could have damaged anything?
FYI..synthetic does make the clutch slip in my bike particularly when cutting off the throttle at high rpms and using compression braking
BadBrad is offline
View BadBrad's Profile View BadBrad's Gallery Find More Posts by BadBrad
Old 01-16-2007, 1:52 PM
So easy a ...
fl-929's Avatar
Bike(s): 01 929
Rep: fl-929 will become famous soon enough (73)
Re: Transmission Abuse
I wouldn't sweat it, but I generally get the answer wrong.
IMO don't bother preloading when shifting, you really don't need to.
01 929
Florida Trackdays
fl-929 is offline
View fl-929's Profile View fl-929's Gallery Visit fl-929's homepage! Find More Posts by fl-929
Old 01-16-2007, 4:54 PM
ichsnoo's Avatar
Bike(s): '02 954RR, '03 FZ1, '93 CBR600, '89 ZXR750
Rep: ichsnoo is on a distinguished road (24)
I would not worry, plus have to agree with fl-929 on not preloading the shift lever. Just decisively shift up as you roll off the throttle without using the clutch. However I would only use this technique from 2nd gear up.
Cheers,
Dave
ichsnoo is offline
View ichsnoo's Profile View ichsnoo's Gallery Find More Posts by ichsnoo
Old 01-16-2007, 5:00 PM
Bike(s): CBR1100XX and 919
Rep: Wockman is on a distinguished road (10)
I wouldn't worry about it. After all its a Honda...
Wockman is offline
View Wockman's Profile View Wockman's Gallery Find More Posts by Wockman
Old 01-16-2007, 8:52 PM
I'm groovin b**ches
jhonda41's Avatar
Bike(s): 95 VFR
Rep: jhonda41 will become famous soon enoughjhonda41 will become famous soon enough (100)
assuming the person has good timing of course.
Badbrad, were you trying to shift without the clutch or did the transmission just slip into neutral? I use synthetic and I've never had this problem (and I have the grandma version of your motor)
Keep in mind if you're not familiar with this technique, that if you roll off the throttle while preloading the shifter, the bike will shift gears. At less than 5,000 rpm as you described, it wouldn't take much of a roll off to get the tranny to pop out of gear. If you're not assertive with this action it will fail to get to second (or other gears) and you get the grinding sound.
Sounds to me like what you've described. I've done that early on when I was learning how to shift and was too lazy to use the clutch. It probably didnt do any serious damage but keep in mind that anytime you hear that grinding noise... it aint good
I rarely use the clutchless technique under 6-7k... it almost defeats the purpose IMO.
-jh
- Track whores get paid for it, track sluts do it for free...
- Cars lean the wrong way in turns.
jhonda41 is offline
View jhonda41's Profile View jhonda41's Gallery Find More Posts by jhonda41 My Map Location
Old 01-16-2007, 9:16 PM
So easy a ...
fl-929's Avatar
Bike(s): 01 929
I should add I usually use the clutch went putting around town. Track stuff or when the rpm's are up it's actually smoother for me to not use the clutch (when upshifting only).
01 929
Florida Trackdays
fl-929 is offline
Old 02-23-2007, 3:02 AM
Bike(s): 06 CBR 600RR
Rep: longbreakdown is on a distinguished road (10)
Sorta related question.... I just got an 06 cbr rr and I'm wondering about shifting into first at a stop. If i'm sitting at a stop, in N, clutch in, and shift into first there is this big (to me) "thump" when I shift. Is that bad?
My old POS bike never did that, so I just wanted to ask you all.
longbreakdown is offline
View longbreakdown's Profile View longbreakdown's Gallery Visit longbreakdown's homepage! Find More Posts by longbreakdown My Map Location
Old 02-23-2007, 7:45 AM
That grinding sound is the gear dogs getting rounded down, hammering against the shift forks. Each time will make it easier to do it the next time. If done enough, it will pop out of gear automatically. Usually happens on the 1st-2nd, where the gear ratio/speed differential is the greatest.
Shift forks and new gears with square dogs aren't too expensive. Its the labor that's the killer.
dattaway is offline
Old 02-23-2007, 9:31 AM
Bike(s): 2002 CBR600F4i
Mine does this too (F4i not an RR like yours though). Every other gear is fine, just shifting down to first at a stop sounds like you dropped a freakin anvil on the ground.
sinfuldragon is offline
Old 02-23-2007, 10:49 AM
Carolina Kracker
Quick 26's Avatar
Bike(s): 06 CBR1000rr, 05 CBR1000RR Repsol Edition(stolen)
Rep: Quick 26 has a spectacular aura aboutQuick 26 has a spectacular aura aboutQuick 26 has a spectacular aura about (211)
both of my cbrs did it so i guess the thud is normal. i have yet to pick up gears off the ground at a stop light so
Quick 26 is offline
View Quick 26's Profile View Quick 26's Gallery Find More Posts by Quick 26 My Map Location
Old 02-24-2007, 10:28 AM
2-Up SISSY
slickwill's Avatar
Bike(s): 2002 CBR 600F4i / 2003 XR650R 'Tard
Rep: slickwill has a spectacular aura aboutslickwill has a spectacular aura about (196)
My F4i thumps pretty bad on that initial shift as well. Since I bought the bike basically brand new I just figured it was normal. I also have missed that 1st to 2nd shift and ended up with a little bit of grinding as well. It isn't something that I want to repeat but it taught me to make that shift much more decisive.
slickwill is offline
Old 02-24-2007, 1:05 PM
That's a very accurate analogy! I was very afraid that I had done something wrong or it was a factory defect.
Thanks all!
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 4:20 PM.
