| 954RR Front end almost complete Hello ,
Just wanted to keep you guys up to date on the 954rr front end .
I have the last of the parts on their way and just sent my second batch of parts to the powder coaters .
I have found some less expensive ways to allow the cbr front end to work with our style handlebars without buying a new triple clamp . I returned my speigler clamp and used the $ on other parts . I ended up using a rc51 upper clamp with dirtbike fat bar clamps on top. works great ! Much cheaper too.
RC51 wheels do not work with the 954rr forks and calipers . spacing issues !!
You could have custom spacers made but I wanted to use factory parts .
I had a rc51 wheel but sold it and purchased a 954 wheel to go with all of the other 954 parts . Works perfect now !
Triple clamp needs to have 954 lower bearing pressed off and 919 bearing
installed . Triple stem diameter is the same from the 919 to the 954 . This was verified using digital calipers .
I will post pics when the project is complete .
Thanks
Ray |
