Need derestrict speed in Hornet 919
Old 08-27-2007, 4:57 AM
Bike(s): Honda CBR954RR
Rep: NewSol is on a distinguished road (10)
Send a message via Yahoo to NewSol
I have a Hornet 919 date 2002 for Asia market-where the law limit speed under 180 km/h.
While the one for European can go maximum 260km/h (see pictures).
Anybody have ideas how to derestrict the limitter in my bike.
Thanks so much for your helping
NewSol is offline
View NewSol's Profile View NewSol's Gallery Find More Posts by NewSol
Old 08-27-2007, 8:06 PM
Bike(s): 2006 919
Rep: Lone Wolff is on a distinguished road (10)
Re: Need derestrict speed in Hornet 919
Perhaps others can confirm, but is the 180 kmh limit mechanical, or simply that the gauge itself won't display anything beyond? If it's just the gauge, swap the Asian one out for the Euro, or North American one. If it's mechanical, someone else would need to help out beyond me.
Lone Wolff is offline
View Lone Wolff's Profile View Lone Wolff's Gallery Find More Posts by Lone Wolff
Old 08-27-2007, 8:59 PM
I found a website show how to derestricted rev limitter in Honda RC51.Can we use for Hornet 919.Anybody have other ideas?Thanks again
http://i24.photobucket.com/albums/c1...huat/b2a15.jpg
This is the simple kit I put together & distribute
http://i24.photobucket.com/albums/c1...at/softkit.jpg
Remove your tail section & undo the T shaped cover attached (4 push pins) on the bottom of the tail section right behind the battery. Under that there will be a black ECU box with a gray connector & a black connector.
This mod is best done with the PCII, as you can do the mod by splicing into the PCII harness instead of the ECU harness & if you ever need to undo the mod you can make it look 100% stock
You can obtain your own connectors from a cd-audio cable (pictured below) as it has the perfect size connectors to match the ECU pins.
http://i24.photobucket.com/albums/c1...t/cd-audio.jpg
http://i24.photobucket.com/albums/c1...uat/wiring.jpg
http://i24.photobucket.com/albums/c1...uat/ecumod.jpg
http://i24.photobucket.com/albums/c1...uat/b2pcii.jpg
Source : RC51 B2-A15 soft rev limiter mod
NewSol is offline
Old 08-28-2007, 4:06 AM
Another solution that I'm thinking to use the speedohealer to convert from km to miles.When I go at 100 m/h the signal send to ECM only 100km/h it mean I can go maxinum 180 m/h -> 180x1.6 = 288 km/h
SpeedoHealer - Electronic Speedometer and Odometer calibrator for motorcycles
I write an email to the techinal engineer of speedohealer for asking
And this is his answer
Hello,
Yes, if you enable the SH''s "kph to mph" conversion mode, e.g. 140 indicated
on your meter will mean 140 mph road speed.
Probably it will also by-pass the speed limiter.
However, we do not have information on whether there is another kind of
restiction (e.g. HP) on this bike for the Asian market.
Kind Regards,
/Norbert
HealTech Electronics
Anybody have experience with this problems.Please help me
Thanks a lot
NewSol is offline
Old 08-30-2007, 12:54 AM
Bike(s): 2004 CB900F (919)
Rep: MaxwellEdison is on a distinguished road (11)
I imagine if anything it's an ECU limiter installed, so you can probably buy a north am or euro ECU, swap it out (probably want the gauges too) and blamo, no limiter.
MaxwellEdison is offline
View MaxwellEdison's Profile View MaxwellEdison's Gallery Find More Posts by MaxwellEdison
Old 08-30-2007, 12:58 AM
lanbrown's Avatar
Rep: lanbrown is on a distinguished road (41)
The RC51 in North America had a soft rev limiter before the hard limit was reached. That mod listed was to get rid of the soft rev portion. This is not the same as restricted bike.
lanbrown is offline
Old 08-30-2007, 3:37 AM
Can you explain the soft rev limitter and the hard limit.Thanks so much.I'm newbie
Another problem : if I change km/h to m/h by speedohealer.Is it enough air/fuel for engine beacause when we in 100 m/h the ECU only think 100 km/h so it will only send air/fuel at 100km/h.
NewSol is offline
Old 08-30-2007, 8:08 AM
Twincam's Avatar
Rep: Twincam is on a distinguished road (36)
Send a message via MSN to Twincam
I bought a Hornet 900 from salvage, and i was not given a key for it. When i later went to the local Honda shop, they stood back and told me i cant get a key made for it, and that i would firstly have to buy and change the complete brain (including the ecu) as you cannot get another key cut - HISS system. The brain would cost me £1000 new or £400 2nd hand.
Dont know about the limiter as mine is in MPH.
Twincam is offline
Old 08-30-2007, 11:39 AM
2-Up SISSY
slickwill's Avatar
Bike(s): 2002 CBR 600F4i
Rep: slickwill has a spectacular aura aboutslickwill has a spectacular aura about (189)
Your air/fuel should be controlled by RPM and O2 input so changing the speed reading shouldn't have an impact.
I would think that by far the best way to go about this would be to get a non-asian market ECU as suggested above.
slickwill is offline
Old 08-31-2007, 2:42 AM
Bike(s): CB900F
Rep: 6pak is on a distinguished road (10)
Hi, I'm in Japan and have similar questions. I am sure the dealer can help out as they do this mod for other Japanese/asian models to open there full potential .
My hornet has a CB900F on the rear fender which from what I have read means it was reimported from Canada (as they don't sell the CB900F and CB600F in Japan), which would mean it shouldn't be restricted , but the speedo only goes up to 180kmh so I am not sure. I have noticed that 4500 revs in 6th gear is about 140kmh. So if I do the math it should go pretty quick if your red lining. So will need to check this out and get back to you ....
6pak is offline
View 6pak's Profile View 6pak's Gallery Find More Posts by 6pak
Old 09-02-2007, 8:20 AM
Thanks for your advice
Waiting your results.
NewSol is offline
Old 09-06-2007, 4:16 AM
Bike(s): CB900F
Hi NewSol
Have'nt been over to the dealer yet. so i dropped him a mail but so far no response. When I get a chance and i'm not riding i will get over there.
6pak is offline
Old 09-11-2007, 1:49 AM
The RC51 wiring diagrams show the black/white wire (B2) from ECU to Fuel injection and Fuel pump show I think the ECU will cut power fuel pump when up to 186 kmh.In that solution they connect B2 with A15 may be to supply power for fuel pump when over 186kmh.That all my guess.
link http://i24.photobucket.com/albums/c1...51-diagram.jpg
The CBR600 wiring diagrams has same with black/white wire from ECU to fuel injection.All the problems we don't know which port can supply power for it when up to 186kmh
link http://i24.photobucket.com/albums/c1...-Wiring-03.jpg
Anybody have ideas?
NewSol is offline
Old 09-19-2007, 6:03 AM
Bike(s): CB900F
NewSol
I talked to the dealer and he will do it for me. As it is illegal to do in Japan he cant give too much detail. but it does require changing the Airbox and mufflres and a wire splice on the ECM loom. I guess when it is done I will get the parts list and can then tell you what I had to purchase. And then get some shots of the splice etc and just reverse engineer the thing? The chain etc are all ok and dont need replacing.
Unfortunately I will wait until after the Japanese MOT (Shaken) before I mod the bike as it is impossible to reregister mod'ed bikes. This will happen in November and then I will do the mod and have 2 years before it needs MOT again. sorry you probably need it now .....
It is expensive mufflers / airbox (but I was getting mufflers anyway. I guess it is about $300 dollars for the parts excluding the muffler.
6pak is offline
Old 09-19-2007, 9:50 PM
  #15
Thanks so much 6pak for your information
I think it have something to restrict air intake and exhaust pipe so that we need to change airbox and muffler
I think they change stock airbox to KN filter for better air flow.
The important in the splice wire.which wire will change postion in ECM?I 'll post my ECM pics in next topic
Still wait your answer maybe after November
Thanks again
P/s how about the speedo metter.Do you need replace new one with max 260km/h?
NewSol is offline
Old 09-21-2007, 3:32 AM
  #16
Bike(s): CB900F
I will definitely get the Euro speedometer
6pak is offline
Old 09-24-2007, 3:51 AM
  #17
If I were you,I only buy speedo healer to convert from kph to mph.It 's cheaper than buying new Euro speedo metter
Could somebody help me by posting your pics of ECM connector (gray & black)?Maybe I 'll find some wire different with mine.
Help me please.
NewSol is offline
Old 09-25-2007, 6:46 AM
  #18
I found a website show how they de restrict Honda CB1300.I think the solution for Hor 919 same
Honda CB1300 | Honda CB1300S | Honda CB1300SA | Honda Forum
De restrict air intake,doing some mod in ECM connector
NewSol is offline
Old 11-09-2007, 3:56 AM
  #20
I had de-retricted my Hornet 919 already.The bike after deretricted very perfect you can feel clearly the increase power.
You can have a look in this website.Sorry it in Vietnamese but i think you can understand with the pictures
http://www9.ttvnol.com/forum/garage/.../trang-10.ttvn
And there are some thread show how to de-restricted CBR 1000RR,Hornet 600...
Thanks all.
NewSol is offline
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 3:42 AM.
