09-15-2007, 4:53 PM
Bike(s): HONDA 919 Posts: 44
| renthal bar's I just put a set of grey renthal road bar's on my 06 919 what a difference-no more right hand tingling a mod that I'm very happy I did.I cut 1 1/4 inch's off both side's so they matched the stock width.Plus it look's cool  |
09-23-2007, 10:36 PM
Bike(s): 02 919, 01 GSXR 600, 04 DR650SE Posts: 147
Rep:  (12) Rep Power: 5
| Re: renthal bar's a great mod
haven't gone the route of rubber clamps but i'm considering it
the renthals really do help w/ the vibes |
09-29-2007, 2:31 AM
Bike(s): Honda 919 Posts: 19
| Re: renthal bar's Sounds like a good mod. Any pics? |
09-30-2007, 5:21 PM
#4 | | Feel The Power Between My Legs
Bike(s): CBR954RR, Hornet CB900F-5, VFR800FI + More Posts: 1,758
Rep:  (36) Rep Power: 3
| Re: renthal bar's The only thing i would say is if you dont chop the ends off, you will have a slightly longer pipe than orginial (problem only if you weave between traffic)
Other than that, its a really nice mod esp as you can get different colours to match the bike. |
09-30-2007, 6:34 PM
| Re: renthal bar's I did chop the end's 1 1/4 per side and bought stock looking bar end's from Oberon in england |
10-01-2007, 12:01 PM
#6 | | Feel The Power Between My Legs
| Re: renthal bar's Quote:
Originally Posted by blackdog I did chop the end's 1 1/4 per side and bought stock looking bar end's from Oberon in england | Yeah i saw in your first post - just shedding light on the others incase they do the modd - ive nearly taken off my ends and bent the bars so many times, might actually chop them...  |
10-01-2007, 12:40 PM
| Re: renthal bar's So, where do you get Renthal road bars? And the oem-style bar ends? I couldn't find them. |
10-01-2007, 1:48 PM
#8 | | Feel The Power Between My Legs
| Re: renthal bar's You can get them over here in the UK, might have to get them sent via mail order or similar from either eBay, or on RENTHAL :: WE BUILD CHAMPIONSHIPS...
The bar ends you can get them from there, or again get them sent from the Uk over using the site previously mentioned by someone. |
10-01-2007, 2:08 PM
Originally Posted by XRsteve So, where do you get Renthal road bars? And the oem-style bar ends? I couldn't find them. |
I got the bars from superbikesupply and the ends from oberon performance in the UK |
10-19-2007, 12:25 AM
Bike(s): XR400 Posts: 17
| Re: renthal bar's These are the Renthal ultra lows.
If you have a Cycle Gear store in your area, they can order them for you. |
10-19-2007, 12:30 AM
Bike(s): 2006 blue and yellow 1krr Posts: 468
Rep:  (13) Rep Power: 1
| Re: renthal bar's looks pretty good... a buddy of mine has a buel that comes stock with them.. it is much better as far as the vibes go.. |
10-21-2007, 6:30 PM
Bike(s): '04 919 '06 KLR 650 Posts: 5
| Re: renthal bar's The stockers are 7/8th's diameter right? Bear with me, I'm kinda new  |
10-21-2007, 10:57 PM
#13 |
Originally Posted by iyaoyas98 The stockers are 7/8th's diameter right? Bear with me, I'm kinda new  | Correct. So are the aftermarket bars. They actually measure a little smaller than the steel bars.
I highly recommend drilling the new bars to accept the locating pin.
Grinding the pin off will let the throttle assy. twist.
Don't worry about the integrity of the bars after drilling. It's a small hole & won't harm a thing.
Just install your controls & test fit to find a comfortable setting for everything. In-out grip position, clutch-brake position, etc.
If you have to cut them down about a 1/2" or so,do it first, then drill for the locating pin.
Put a little mark on it with a marks-a-lot type marker. Then, position the throttle where you want it, & give it a little twist and an in & out motion, to scribe an "x" if you will, to create the drill center.
Drill,mount, & your done. |
10-22-2007, 12:33 AM
#14 |
Bike(s): CB900F Posts: 13
| Re: renthal bar's Wow XR's those ultra low renthals look great.... |
10-22-2007, 10:58 PM
#15 |
| Re: renthal bar's Thank you. |
10-23-2007, 8:31 PM
#16 |
Bike(s): Stock 2003 919, 2006 Yamaha R6 Posts: 27
| Re: renthal bar's How much are the 7/8 renthals and where can I get them? |
11-10-2007, 9:00 PM
#17 |
| Re: renthal bar's I can buy them in Japan , so I am on my to go check them out ... |
04-12-2008, 8:03 PM
#18 | | Been down that road...
Bike(s): '03 919 '97XR400 '72TrumpB50MX '94XR600R '03Blast Age: 59 Posts: 257
Rep:  (12) Rep Power: 2
| Re: renthal bar's These are TAG bars for a KX80, you don't need to cut them off.
The bars for the smaller dirt bikes are already shorter but just as strong.
04-13-2008, 10:52 AM
#19 |
Bike(s): 1981 Kawasaki KZ750E, 2007 Honda 919 Posts: 28
| Re: renthal bar's Do the hand grips hit the tank at full lock? This would be my main concern. |
04-13-2008, 1:25 PM
#20 | | Been down that road...
| Re: renthal bar's no, they don't even come close, plenty of room as shown in this photo with the steering locked left.
