Undertail options for the 919
Old 11-03-2007, 7:42 PM
Bike(s): 2004 CB900F (919)
Rep: MaxwellEdison is on a distinguished road (11)
Are there any? Having a hell of a time finding one. Reason I ask is because my stock one the right side mount hole that the hex head bolt goes through is broken (hole is split, bolt slides out) and is all hanging and scratching up my tail . Any help is appreciated.
MaxwellEdison is offline
View MaxwellEdison's Profile View MaxwellEdison's Gallery Find More Posts by MaxwellEdison
Old 11-05-2007, 1:25 PM
Bike(s): '04 Honda 919
Rep: 919hooligan is on a distinguished road (10)
Re: Undertail options for the 919
I have a Jardine Supersport Fender Eliminator on mine, way smaller than stock but still uses factory signals. Easy to install. Also Competition Works (Werks?) makes one that's smaller than the Jardine but it uses smaller signals. Those are the only two options I am aware but there may be more available now.
If I understand you correctly the mounting location on your bike is busted, the Jardine uses the factory mount locations so you will have to fix that first. I'm not sure about the CW eliminator. If the plastic on your bike is busted at mounting hole try to use a big washer (fender washer-available at Fastenal and most electrical supply stores), otherwise maybe try to use a good two part expoxy to fuse it back together then use an oversized washer as a precautionary measure to help keep it from coming back apart.
Hope this helps.
919hooligan is offline
View 919hooligan's Profile View 919hooligan's Gallery Find More Posts by 919hooligan
Old 11-13-2007, 6:04 PM
Bike(s): Honda 919
Rep: XRsteve is on a distinguished road (10)
Does anybody have a pic or the Jardine kit?
XRsteve is offline
View XRsteve's Profile View XRsteve's Gallery Find More Posts by XRsteve
Old 11-14-2007, 6:02 AM
Bike(s): 2007 Suzuki Bandit 1250SA
Rep: KenB will become famous soon enough (59)
I went with an easier solution. Remove the snow shovel from the rear end. Install a tail light / turn signal light LED. Cut a piece of angle iron to hang the plate. Cheaper than the kits and looks better too. Good luck!
KenB is offline
View KenB's Profile View KenB's Gallery Visit KenB's homepage! Find More Posts by KenB
Old 11-14-2007, 8:10 AM
SuperSneakySteve went this route also and has posted some video on Utoooob showing what he did.
XRsteve - I don't have a digital camera or I'd post a pic but basically it's a black aluminum plate that allows the license plate to be mounted in the same location as factory and the factory signal mounts are hidden behind the plate. There is room above the where the license plate mounts to mount the tag light if you're interested in keeping it. It does not extend below or out to sides behind the license plate. I went this route because I wanted to use the factory signals and also have room to mount my tag light. 100% better than factory flap but if you're going to use aftermarket signals I would recommend the Competition Werks. If you're thinking about an integrated tail light/turn signal I'd make one out of aluminum angle. Just my 2 cents.
Old 11-14-2007, 7:15 PM
Bike(s): Ducati 748, 919
Rep: CBRrr is on a distinguished road (13)
Made mine from a 3/16" of aluminum stock 3/4" x license plate width. Attached it to the flat area of the OEM undertail below the tail light. For a clean look, the smoke tail light is an LED Clear Alternatives with integrated signals. Then I finished it off with a DRC micro LED strip license plate light, so small you can't see it.
http://i34.photobucket.com/albums/d1.../919_done5.jpg
CBRrr is offline
View CBRrr's Profile View CBRrr's Gallery Find More Posts by CBRrr
Old 11-15-2007, 6:55 AM
My bad. I t was aluminum and not iron. SS Steve made up a batch of them and sold them for the cost of shipping last Winter. It worked great. At one point I moved the plate up under the seat but the road spray started to take a toll on the tail light and rear cowling so I put the plate back. That's why it's angled out the way it is in the photo above.
KenB is offline
Old 11-15-2007, 7:39 PM
I found an old pic a had of the Jardine Kit. If I can get this to work..........
Name:	Jardine Fender Kit.JPG
Old 11-16-2007, 2:36 PM
Bike(s): Honda 919
The Jardine kit looks good. I think that's what I'm going to get.
BTW, MaxwellEdison, are you majoring in medicine?
I wonder how many people get that.
XRsteve is offline
Old 11-16-2007, 8:57 PM
Actually, my real name is Maxwell, and I know I'm named after that song (don't like to think about why)...
Old 04-06-2008, 9:02 PM
Bike(s): Honda 919
I installed a Jardine supersport kit on my 06 919 a few weeks back. It was a fairly simple install, except I had to use a hole saw to make a hole for my stock license plate lamp. It turned out pretty good, so I thought I'd share some pictures.
XRsteve is offline
Old 04-07-2008, 10:51 PM
Bike(s): '02 Honda 919
Rep: mitsubishimarc is on a distinguished road (10)
so has anyone had any experience with actual "undertails" or just the fender eliminators. i saw that Pyramid makes one for the 919 but haven't seen any applications of it other than the one picture they provide.
mitsubishimarc is offline
View mitsubishimarc's Profile View mitsubishimarc's Gallery Find More Posts by mitsubishimarc
Old 05-29-2008, 11:29 PM
Bike(s): 2002 919
Rep: streetfighterz6 is on a distinguished road (10)
Go to freestreetdesign.com is a french web site however they have some cool stuff!
streetfighterz6 is offline
View streetfighterz6's Profile View streetfighterz6's Gallery Find More Posts by streetfighterz6
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 5:43 PM.
