| Re: How change the time in the control dysplay??? I don't remember exactly off-hand, but you push the right select button to get the clock in the screen, then you either press and hold the right button for a few seconds until the clock starts blinking, or your press both select buttons, either way, once it starts blinking, the left select button is the hour, the right select button is the min. Once you have the time correct, turn the key off, then back on to lock it in. Or you can just ignore it and it'll quit blinking in about 15 seconds. BTW, this is or course done with the engine off. I'll go check later on today and make sure, but I'm 99% sure this is right. Be safe, and get an MSF course, especially if a 919 is your first bike. |
