| Honda Naked Sportbikes Discussion of the Honda 599, Honda 919, and Honda CB1300 Motorcycles. |
06-19-2008, 6:35 PM
Reputation Power: 0 | 919 vibration
hi to everybody, I bought a new 2007 919 ,and after 1500 miles I still have a vibration that I think come from the motor. Is anybody had this problem before and what do you think it come from... thank you! |
06-19-2008, 11:57 PM
#2 | | Been down that road...
Reputation Power: 4 | Re: 919 vibration
with the stock front sprocket they are buzzy at Interstate speeds. wht kind of vibration is it?
06-20-2008, 7:23 PM
Reputation Power: 0 | Re: 919 vibration
Īt,a vivration that goes to the handle like a electrical chock.
06-20-2008, 7:51 PM
#4 | | Been down that road...
Normal for the 919 if it occurs at about 75 to 80 mph.
If you buy a front sprocket with one more tooth (17), it will lower the rpms about400 and the buzz won't happen until about 85 to 90 mph.
You loose the ability to power wheelie but not too many people riding a 919 are into that.
06-21-2008, 9:05 AM
thank you guys !
06-21-2008, 11:15 AM
Reputation Power: 0 | Re: 919 vibration http://www.fireblades.org/forums/hon...nthal-bar.htmlGet renthal bars to eliminate the buzz not just move it then get 15/45 gears and you will power wheelie your @$$ off.
06-22-2008, 7:29 AM
#7 | | Supporting Member
Reputation Power: 5 | Re: 919 vibration
Add a tooth, get some better grips, wear good boots, add some Renthals, and consider some bar ends. But remember you're riding an inline 4 with its sleeves rolled up. Some buzz is expected.
08-28-2008, 5:52 PM
what kind of "better grips" and "bar ends", any suggestions?
08-28-2008, 8:44 PM
#9 | | Been down that road...
15 tooth will eat back tires like they're jelly doughnuts! But just as much fun.
11-01-2008, 9:24 PM
I just had handlebars from a cb750 nighthawk installed (2" wider 1.5" higher), they came with the weights already inserted in the bar ends. I also had the original bar end weights retro fitted. The engine feels the same riding around town but it is MUCH smoother at 60 mph and over.
11-01-2008, 9:59 PM
I just installed a Throttlemeister (heavy) and that seems to have helped quite a bit especially at higher rpm's/speeds.
02-02-2009, 5:58 PM
I have an '07 919 that I wanted to knock some of the chrome off of a little bit...so I bought Renthal "Street Fighter Meduim" bars that looked great, but were 3 inches longer than stock (1.5"/side).
I thought about cutting them down...but noticed there would not be enuff straight bar to mount lever-perch, switch-gear, and grips.
I thought about using them as is (long) but this would have required cable adjustments from clutch, brake, and throttle cable/lines that I wasn't in the mood to perform. I only found out later that I also would have had to contend with locating pins and some drilling.
So, I had the stock bars stripped and powder coated black. They look great, but I am now getting a buzz that was not there before, especially the left side where at free-standing idle the clutch lever will vibrate and rattle like a beehive.
I'm reasonably sure I have the bar-end weights attached correctly.
I am at a loss trying to figure out what went wrong...and how to correct it. :-/
02-02-2009, 10:59 PM
#13 |
Hmmmm.....I don't see how powder coating could possibly cause the vibration. Have you tried loosening and re-tightning the pinch bolts, making sure their even? The clutch rattle at idle is normal. Oh yeah, I live in SD too.
03-22-2009, 9:42 AM
#14 |
Reputation Power: 2 | Re: 919 vibration
took my 919 on highway for first time all stock ... was waiting for the bar buzz didnt get it tryed from 70 up to 100 ...i did notice the clutch lever vibration at idel...bike is smooth as silk and quiet ..im thinking different exhaust would create more bar buzz are the complants with bikes with stock exhaust
| | | | Visitors found this page by searching for: | honda 919 handlebar vibration, honda hornet clutch rattle, http://www.fireblades.org/forums/honda-naked-sportbikes/65811-919-vibration.html, front sprocket honda 919 2002 origonal, honda 919 bars, honda 919 front end vibrates at 60, honda 919 renthal bars, Honda CB 919 Hornet handlebars, honda 919 rpm at 90 mph, honda 919 straight bar, throttle meister honda hornet, honda cb 919 mph, honda 919 bar buzz, honda cb 919 levers, honda hornet vibration, honda 919 lever, honda 919 hornet wheelie, honda cb 900 bar ends loose, 2007 Honda 919 0 to sixty time, honda cb 750 motor vibrates, honda 919 vibration, honda 919 idle speed, honda 919 vibration on acceleration, honda 919 bar ends, Renthal bars for Honda 919 | |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | |
