Tire replacement.Question. Loctite?
07-13-2009, 12:24 AM
Join Date: 07-12-2009 Location: Ga Boy hanging out in NC
Bike(s): Stock Hoda 919 (2007) Posts: 13
| Tire replacement.Question. Loctite? OK guys I'm pulling the front and rear tires off my bike to put new rubber on it. When I go back on with everything should I put a drop of the Blue Loctite on the bolts on reassembly ?? I'm going to torque them to the spec's in the book. Calipers and axle nuts and such. Hey Ive done dirt bikes before. But not a machine that I'm riding fast enough on and asphalt under my ass ..LOL...  Ive read the how to's. Anything special I should know before I undertake this thing??? Rocket Science ain't it.....  Thanks WD |
07-13-2009, 1:09 AM
Bike(s): 2007 Honda CBR1000RR & 1992 Honda CBR600F2 Posts: 349
Rep:  (25) Rep Power: 3
| Re: Tire replacement.Question. Loctite? I have used a few drops of loctite on the front axle clamp bolts. I have not used it on the axle bolts or chain adjusters. I have also used loctite on the front brake caliper mounting bolts. You should pull the calipers when you remove the front wheel. This prevents damage to the pads when you reinstall the front wheel. Hang the calipers by some string rather than let them dangle from the brake lines. |
07-13-2009, 6:46 AM
| Re: Tire replacement.Question. Loctite? Thanks... WD |
07-13-2009, 8:37 AM
Bike(s): CB750, GL1000,CBX, Blackbird, 2005 CBR 1000rr Posts: 1,185
| Re: Tire replacement.Question. Loctite? I really don't think Loctite is necessary if fasteners are torqued to spec. I might use it where you have a specific problem, maybe. Even blue or medium strength can mess up aluminum threads sometimes. |
07-18-2009, 2:26 AM
Bike(s): 2004 919 Posts: 53
Rep:  (10) Rep Power: 2
| Re: Tire replacement.Question. Loctite? chain adjusters on 919 actually have a bad tendency to come loose if you don't watch them, but safety wire is a better way to secure the chain adjusters. |
07-18-2009, 2:32 AM
#6 | | WYSIWYG
Bike(s): 2003 954 fireblade Age: 53 Posts: 6,969
| Re: Tire replacement.Question. Loctite? Quote:
Originally Posted by zookmor chain adjusters on 919 actually have a bad tendency to come loose if you don't watch them, but safety wire is a better way to secure the chain adjusters. | Or replace the locking nut with a Nylex one.
__________________ I was young and stupid then. I'm old and stupid now. We get too soon old, and too late smart. |
07-18-2009, 9:20 AM
Originally Posted by zookmor chain adjusters on 919 actually have a bad tendency to come loose if you don't watch them, but safety wire is a better way to secure the chain adjusters. | I'm not exactly sure of the chain adjust system on the 919 but if it's like most, after the chain has been adjusted and the axle nut has been torqued, you should always snug up the adjuster bolts now that the axle can't move and then tighten the jam nut. Makes everything more solid. |
07-18-2009, 2:10 PM
#8 | | Well...
Bike(s): '04 CBR1000RR, '84 Ascot, '02 RC51 Posts: 14,169
Originally Posted by segiano I have used a few drops of loctite on the front axle clamp bolts. I have not used it on the axle bolts or chain adjusters. I have also used loctite on the front brake caliper mounting bolts. You should pull the calipers when you remove the front wheel. This prevents damage to the pads when you reinstall the front wheel. Hang the calipers by some string rather than let them dangle from the brake lines. |  On the RC I just put the top bolt back in the caliper and hang it that way though.
