Torque spec question (919) Rear brake calipers.
Old 07-18-2009, 9:04 PM
Bike(s): Stock Hoda 919 (2007)
Rep: WarDawg is on a distinguished road (10)
Hey guys I Just finished putting a new set of Diablo's on my 919er. I got a little quick and took the rear caliper off the mounting bracket. No need in taking it off the bracket, it comes off when you remove the tire. . The rear has two bolts .A 12mm and a 14mm . The front caliper specs are 22Ft lbs . Since I didn't have the info for the rears I just torqued them 22Ft lbs also. Does anyone have the rear specs? Oh the new rubber feels awesome !! WarDawg
WarDawg is offline
View WarDawg's Profile View WarDawg's Gallery Find More Posts by WarDawg
Old 07-24-2009, 2:40 AM
Bike(s): 2007 Honda 919
Rep: 919dude is on a distinguished road (10)
Re: Torque spec question (919) Rear brake calipers.
REAR WHEEL/SUSPENSION: (kgf-m/ ft-lbs)
Rear brake disc bolt (4.3/ 31)
Final driven sprocket nut (11.0/ 80)
Rear axle nut (9.5. 69)
Rear shock absorber upper mounting bolt (4.3/ 31)
Rear shock absorberupper mounting nut (4.3/ 31 )
Drive chain slider flange bolt (0.9/ 6.5)
This is strait from the official Honda Service Manual. Hope it helps! If I can provide any other specs, let me know, I'll look them up.
919dude is offline
View 919dude's Profile View 919dude's Gallery Visit 919dude's homepage! Find More Posts by 919dude
Old 07-24-2009, 12:05 PM
Thanks.. I use to live in Tacoma.... in the ealry 90's... Parkland and Spanaway area..... Tule Lake rd near Washington Highschool. I took a machinst course at Clover Park Tech school also. The specs I need is the two bolts that bolt the Caliper on the mount. One is a 12mm and one is a 14mm . Like I stated I went and torqued them at 22 Ft.pnds since the fronts was that spec. But I'm just checking.. Thanks again... WarDawg
WarDawg is offline
Old 07-24-2009, 12:33 PM
Sorry, WarDawg, I sent you the wrong specs. Here are ALL specs for brake parts, including the rear caliper.
The numbers are: (how many/thread diameter/NewtonMeters) and (kgf-rn, Ib·ft)
I hope you can figure out the numbers, based on what I typed above. The important ones are the ones in blue: thread diameter and the ones in red: lb-ft torque setting. Had to try it this way since these specs were copied from an Adobe Document and pasted here, something that always seems to take some fixing after the paste job. And it takes about 15-20 minutes of editing and re-editing to get these specs to show up unjumbled and neatly. If you need other specs, maybe just shoot me a PM and I'll PM or e-mail them to ya.
Hope this helps!
HYDRAULIC BRAKE:
Front master cylinder reservoir cap screw 2/4/1 (0.1, 0.7)
Front brake lever pivot bolt1/6/1 (0.1, 0.7)
Front brake lever pivot nut1/6/6 (0.6, 4.3)
Front brake light switch screw1/4/1 (0.1, 0.7)
Front master cylinder mounting bolt2/6/12 (1.2, 9)
Front brake caliper assembly torx bolt8/8/32 (3.3, 24) NOTE 2
Front brake caliper mounting flange bolt 4/8/30 (3.1, 22) NOTE 6
Rear master cylinder push rod lock nut1/8/17 (1.7, 12)
Rear master cylinder mounting bolt2/6/10 (1.0, 7)
Rear brake caliper bracket bolt 1/8/23 (2.3, 17)
Rear brake caliper pin bolt 1/12/27 (2.8, 20)
Pad pin 3/10/17 (1.7, 12)
Pad pin plug 1/10/3 (0.3, 2.2)
Brake hose oil bolt 3/10/34( 3.5, 25)
Brake caliper bleeder valve3/8/6 (0.6, 4.3)
Step holder mounting bolt4/8/27 (2.8, 20)
Rear master cylinder hose joint screw2/6/10 (1.0, 7)
NOTES: (from above only)
2. Apply a locking agent to the threads.
6. ALOC bolt/screw: replace with a new one.
Last edited by 919dude : 07-24-2009 at 12:51 PM. Reason: because it takes 8-10 tries to get stuff not scrambled around.
919dude is offline
Old 07-24-2009, 12:53 PM
Originally Posted by WarDawg View Post
One is a 12mm and one is a 14mm.
I'm guessing you're talking about the socket size because there are no bolts back there with 14mm thread diameters according to the manual.
Wish I had a way to just send you a copy of this manual, but it's 432 pages in Adobe, and is 84.4MB in size!
919dude is offline
Old 07-24-2009, 1:27 PM
Just what I needed. ( Rear brake caliper bracket bolt 1/8/23 (2.3, 17)
Rear brake caliper pin bolt 1/12/27 (2.8, 20) )
I wasn't to far off. I see I needed 17 ft lbs for the 12MM bolt . And 20 ft. lbs for the 14mm bolt. I put them both at 22 ft lbs.. Thank you for your time in looking for this info. I'm off to the mountains in the curves tomorrow . WarDawg
WarDawg is offline
Old 07-24-2009, 2:39 PM
Coolness. Glad I could help. If you need anything else looked up for your 919, let me know. Like specs or stuff.
919dude is offline
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 12:18 PM.
