900/919 interchangeability/commonality/modifications
Old 09-18-2009, 9:50 AM
Bike(s): Honda CB919
Rep: tarenson is on a distinguished road (10)
Got some questions on the 919's mill. Are the valves larger in the 900 and can a larger valve be used in a 919? (Aftermarket valves 1 mm larger can be had). Can custom aftermarket pistons for a 900 be used in a 919? (I believe 3 mm overbore forgings are available --can a 919 take an overbore that large, and if so, will it require larger sleeves; can it even be resleeved?) Can aftermarket cams for the 900 be used with the 919? How about a thinner headgasket to up compression -- is it safe considering the 919 has cast pistons? (Say, going to 11.5:1 and using premium fuel). How 'bout extrude-honing the 919's fuel injector body? Also, what about ARP rod bolts? I hear the 919's rods are good, but need better bolts. Any information would be appreciated -- Thanks!
Last edited by tarenson : 09-18-2009 at 10:27 AM. Reason: Add question about rod bolts; clean up punctuation, grammer
tarenson is offline
View tarenson's Profile View tarenson's Gallery Find More Posts by tarenson
Old 10-21-2009, 2:37 AM
Vr4
Bike(s): 02 919
Rep: Vr4 is on a distinguished road (10)
Re: 900/919 interchangeability/commonality/modifications
And what about the front forks?
Anyone have any experience?
Vr4 is offline
View Vr4's Profile View Vr4's Gallery Find More Posts by Vr4
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 7:05 AM.
