CBR600 F4 / F4i Forks on a 919
10-21-2009, 3:14 AM
Bike(s): 02 919 Posts: 9
| CBR600 F4 / F4i Forks on a 919 Hello guys!
I Bent my forks again today  - But you should have seen the car I ran into! I This was all on my 2002 919.
Anyone have an insights on what other forks are a direct bolt up to the 919. [Same spacing / travel, brake mounts, etc?]
I heard that F4 / F4i forks bolt up direct. Can anyone confirm this? I want to just slip out my old tubes and slip in some new ones. I can seem to find Used 919 Forks anywhere
The 5th post here says that f4 forks are a direct bolt up: 919 went belly up
And direction would be awesome! |
10-21-2009, 3:40 AM
Bike(s): 02' 954 Posts: 96
Rep:  (59) Rep Power: 1
| Re: CBR600 F4 / F4i Forks on a 919 in 2002 they made a 954.... in 2000-2001 they made a 929.....if it is a 929 then the 954 forks should bolt right up. check your vin. I can't remember the site at the moment but someone can help i bet. |
10-21-2009, 3:46 AM
| Re: CBR600 F4 / F4i Forks on a 919 hey - thanks for the reply - but the Honda 919 - Is also known as the cb900r
Sounds like 929 -but is a very [much cooler] different bike  |
10-21-2009, 4:59 PM
| Re: CBR600 F4 / F4i Forks on a 919 oh my bad :0 |
10-21-2009, 5:03 PM
#5 | | Out Of Many, We Are One
Bike(s): CBR954RR, Hornet CB900F-5, VFR800FI + More Posts: 6,906
| Re: CBR600 F4 / F4i Forks on a 919 Quote:
Originally Posted by Vr4 hey - thanks for the reply - but the Honda 919 - Is also known as the cb900r
Sounds like 929 -but is a very [much cooler] different bike  | Its a CB900F- (what ever year yours is ... mine is CB900F-5)
10-21-2009, 5:07 PM
#6 | | Out Of Many, We Are One
| Re: CBR600 F4 / F4i Forks on a 919 I'm not sure if the Hornet 599/600 would fit on the 919?
10-21-2009, 9:58 PM
| Re: CBR600 F4 / F4i Forks on a 919 good question about the hornet... any ideas how i could check? |
10-22-2009, 6:33 PM
#8 | | Out Of Many, We Are One
| Re: CBR600 F4 / F4i Forks on a 919 I'm not sure how to check, maybe you would have to check the length in fork tubes? (Sorry but I really haven't got a clue... Maybe you could retain the original springs or upgrade the ones in the 599 forks if you were to go for them and if they fit of course?)
10-24-2009, 9:04 AM
Bike(s): Honda 919 aka Hornet900 Posts: 4
| Re: CBR600 F4 / F4i Forks on a 919 Hi guys
I’m the next one with Honda 919 (aka Hornet 900) with bent forks and rim.
Will someone confirm the forks/front wheel off a CBR600F4 is a bolt on swap?
Does it go the same for CBR600F4i ?
Thanks |
11-03-2009, 2:36 AM
Bike(s): '05 919 HORNET Age: 28 Posts: 40
Rep:  (11) Rep Power: 0
Thanks | The F4i fork legs slide right in. Here they are on mine (which is for sale) |
11-03-2009, 9:34 AM
| Re: CBR600 F4 / F4i Forks on a 919 That looks great! Do the calipers from 919 bolt right up? Is that a f4i fender? Is the length the same as 919 forks? |
11-03-2009, 12:26 PM
Originally Posted by Vr4 That looks great! Do the calipers from 919 bolt right up? Is that a f4i fender? Is the length the same as 919 forks? | That's a full F4i front end. From what I see, yes they are the same length, I can give you a definite tonight though. |
11-03-2009, 3:55 PM
#13 |
Originally Posted by BMiller ... From what I see, yes they are the same length, I can give you a definite tonight though. | That would be great, I'm already bidding for a pair of F4 forks |
11-04-2009, 1:51 AM
#14 |
| Re: CBR600 F4 / F4i Forks on a 919 Quote: |
Originally Posted by rickard919 Quote: |
Originally Posted by Vr4 Hey - you made a great comment in a thread about being able to directly swap out the honda 919 fors with cbr f4 / f4i forks. Do you know if this is actuall ytrue? Are the forks the same height?
thanks - and you are the MAN!
thanks! | sorry I didn't respond sooner. The forks will swap straight over. Same length and diameter. You just need the F4 fender. The calipers will bolt right up. | So - it looks like it is a go! Just need a f4/f41 fender. Are the f4 forks better then pree 2004 919 forks? |
11-04-2009, 8:50 PM
#15 |
Hey! - Thanks for the reply! The stock 919 calibers will bolt right up? With the calipers did it make any difference with the year bike? Didnt the calipers change after 04? Wheel fit with stock 919 axel?
Thanks soooo much! I actually started a thread about this. Do you mind If I quote your reply?
thanks again! Re: 919 forks
I haven't done the conversion but my understanding from Wrist twisters is it is a straight swap. buy the forks and fender, use the 919 calipers and wheel axel and spacers. The only change on calipers was from black to the gold ones.
You should go to wristtwisters.com Over there is hundreds of guys with 919's and lots of info. Everyone helps each other by selling old parts and even giving stuff away for free.
Join and introduce yourself.
ok Im jumping over to wrist twisters!
thanks everyone for all your help! |
