2003 CRF450R Hard Start - Honda Motorcycles - FireBlades.org
Honda Off-Road Discussion of Honda Off-Road Vehicles, including Honda Dirt Bikes, Honda ATVs, Honda 4-Wheelers, and Honda Watercraft.
post #1 of 9 Old 04-08-2013, 2:32 PM Thread Starter
i am having the hardest time getting this things to start and stay running the running part is because of the idle needing to be adjusted anybody know the location of the idle screw and as for the hard start t i have to perform a ritual to even get it to kind of start. ritual= shut fuel off put in neutral and then pull hot start and then kick like hell and then sometimes it will start any ideas on why its so damn hard to start its hard to kick also my plan is to disassemble the carb today and clean it and put it back together any suggestions and can i use carb cleaner or should i just use air?
Thank you and god bless
Doyle95 is offline
post #2 of 9 Old 04-08-2013, 6:41 PM
Images: 2
Quoted: 2 Post(s)
Reputation Power: 227
Re: 2003 CRF450R Hard Start
Is this a problem that just started?
Are you bringing it past compression before kicking through?
Is the decompressor working?
Have you checked the valve clearances?
Are you keeping the throttle closed?
If you need to shut of the fuel then perhaps it's flooding?
How many hours the spark plug?
How many hours on the oil?
The idle adjuster will be someone on the carb I would expect.
Part #12
Ronayers.com Microfiche Honda>Motorcycle>2003>CRF450R>CARBURETOR
Yes, strip the carb completely including the choke circuit and mixture screw, soak everything in carb cleaner and blow it all through with compressed air checking that fluid does actually pass through every orifice.
post #3 of 9 Old 04-08-2013, 9:57 PM Thread Starter
I just got the bike last Wednesday so I'm not sure
Yes I am
I believe so
No I have not probably need to be done how hard is that and reshimming
Yes throtttles closed
That's what I was thinking also
I think the spark plug has a ton of hours especially since it down to a needle point lol
Oil has 6hours on it changed it before I went on my ride this weekend
It's also seems like its hard to kick it seems like but it could just be me I haven't ridden in years lol
Doyle95 is offline
post #4 of 9 Old 04-08-2013, 10:44 PM
Reputation Power: 11
Those bikes are very finicky about their service intervals...check valve adjustment almost certain this is your issue.
First thing I would do to CRF250/450...seen enough at the shop to know.
unlucky69 is offline
post #5 of 9 Old 04-08-2013, 10:47 PM Thread Starter
How hard are they to adjust?
Doyle95 is offline
post #6 of 9 Old 04-08-2013, 10:47 PM Thread Starter
And what is entailed in doing that
Doyle95 is offline
post #7 of 9 Old 04-09-2013, 5:16 AM
Images: 2
Quoted: 2 Post(s)
Get a manual and just follow the instructions.
Checking the clearances simply requires removing the valve cover, putting the engine on TDC and measuring the clearances with feeler gauges.
Adjusting the shims requires pulling the camshaft so you can replace the shims.
post #8 of 9 Old 04-09-2013, 8:00 PM
Quite easy if you are patient and have decent mechanical skills. If you don't then paying someone to check/adust the valves is highly recommended.
post #9 of 9 Old 04-09-2013, 8:03 PM Thread Starter
Ya I called a local engine builder and its gunna be 300 for a complete valve adjustment and gaskets and a complete carb rebuild so that sounds good to me
Doyle95 is offline
Go Back   Honda Motorcycles - FireBlades.org > Honda Motorcycle Models > Honda Off-Road
Human Verification
Search tags for this page
2003 crf 450 hard to start
2003 crf450r problems
2003 honda crf450r won't start
2007 honda crf450 hard to kick start
crf 450 wont stay running
crf450r wont start when hot
does my honda crf450r 2009 have a hot start
honda crf450 starting instructions
how to adjust the idle screw on a 2004 cr f 450 r
why is it hard to start crf 450
954 hard to start sometimes Insomnia Honda FireBlade 14 02-23-2013 2:43 PM
Hard to start when warm? Kaalakaikoa_954 Honda FireBlade 6 02-29-2012 11:06 AM
05 CBR1000RR Hard To Start Mil 35 darkspy Honda FireBlade 0 06-29-2011 11:55 PM
1999 Fireblade hard start, now wont start.... MFB_87 Honda FireBlade 15 03-18-2010 11:58 PM
900rr hard to start pajazo Honda FireBlade 24 06-03-2007 10:07 PM
