Go Back   Honda Motorcycles - FireBlades.org Forums > Honda Motorcycle Models > Honda Off-Road
Honda Off-Road: Discussion of Honda Off-Road Vehicles, including Honda Dirt Bikes, Honda ATVs, Honda 4-Wheelers, and Honda Watercraft.
OK tore apart the KTM
Old 10-09-2004, 7:54 PM
Bike(s): 2000 Fireblade, 02 GSXR 600 Track Bike (sold)
Rep: ucfmotorcycle1 will become famous soon enough (65)
Looks like it overheated like I thought and the piston seized. So now I ordered the Wiesco pisont, ring, bearing, gasket kit, and sent the cylinder to get bored and replated. Stealer charged me $390 . Is this high? Also there is the matter of the coolant leak. The was very little coolant in the bike when this happened and I filled it before I left so it is leaking somewhere. I think its internal because I didn't notice any visible signs. Any ideas? I don't wanna throw all this stuff back on and have it overheat again. I hope maybe with all the new topend gaskets it will solve the issue but is there anywhere else I can check for coolant leak???
ucfmotorcycle1 is offline
View ucfmotorcycle1's Profile View ucfmotorcycle1's Gallery Find More Posts by ucfmotorcycle1
Old 10-09-2004, 8:01 PM
Compromise
sheepofblue's Avatar
Rep: sheepofblue has much to be proud ofsheepofblue has much to be proud ofsheepofblue has much to be proud ofsheepofblue has much to be proud ofsheepofblue has much to be proud ofsheepofblue has much to be proud ofsheepofblue has much to be proud ofsheepofblue has much to be proud ofsheepofblue has much to be proud ofsheepofblue has much to be proud of (1354)
Re: OK tore apart the KTM
Pressure check the system for leaks. Most auto shops have a tool that you apply a small amount of pressure and watch the gauge to verify the system. The only question is an adapter to fit your system and I bet they can handle it.
sheepofblue is offline
Old 10-09-2004, 8:21 PM
Oh yeah I should have thought of that . Anyway I think it is leaking into the tranny because the gear fluid is nasty and I just changed it. I'm not too familiar with dirtbike anyone know which seal is that?
Old 10-09-2004, 10:21 PM
G-Force Junkie's Avatar
Sounds like a water pump seal. $390 for the wholething, or just the replate? I know places to get it replated for about $175 like Melinnuim, US Chrome, Poeton, etc.
G-Force Junkie is offline
Old 10-10-2004, 12:50 PM
$390 for all the parts listed (piston, ring, bearing, gasket kit, and replate). I have also been looking all over for a shop manual for the thing and can't find it. I hope the water pump seal comes with the gasket kit.
Old 10-10-2004, 1:40 PM
Doubt it, probaly just a top end gasket set. If its that old, make sure they pressure check it to make sure the cases arent leaking either.
Old 10-10-2004, 3:49 PM
No I bought the complete gasket set and I am working on it myself. I am pretty good with mechanics just never worked on a 2 stroke dirtbike before.
Old 10-13-2004, 2:05 PM
Mavic's Avatar
Bike(s): 2001 929 Red and Black & 1987 CR500
Rep: Mavic is on a distinguished road (10)
Oil and water will not mix so if you have water in the crank case it should be fairly evident. If you indeed have water in the crankcase you will need to purchase a couple of parts to make the repair. Number 1 task will be to get the impeller out/off the shaft. Not sure on the KTM300. My 500's have a seperate impeller shaft onto which the impeller threads. When you try to remove the impeller it usually fails and strips out and you end up replacing the impeller shaft and impeller then if I recall correctly there will be 2 seals separating the water and crankcase. They usually have a weep hole drilled between the seals that will leak water if one of the seals is compromised.
However, you could still have a crankcase air leak as this can result in a very lean condition and get a similar seize. In either case, pressurized testing is the trick to identification. The cooling system being the easiest to test.
On another point, make sure who ever bores your cylinder knows that you are putting a wiseco piston in as the forged piston and plated cylinder wall have dissimilar expansion rates and if bored too tight, cold seizing can result. Check Eric Gorr for pricing on top ends as he is one of the best in the business and seems very fair in the pricing vs service category.
Mavic is offline
View Mavic's Profile View Mavic's Gallery Visit Mavic's homepage! Find More Posts by Mavic
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 1:08 AM.
