 1 Hour Motorcycle & Car Loans    Honda CBR's Exhaust Systems  CBR Eliminators Helmets Boots Stickers
Go Back   Honda Motorcycles - FireBlades.org Forums > Honda Motorcycle Models > Honda Off-Road
Honda Off-Road: Discussion of Honda Off-Road Vehicles, including Honda Dirt Bikes, Honda ATVs, Honda 4-Wheelers, and Honda Watercraft.
83 XR200 Tranny/Clutch Problem
Old 07-17-2005, 9:25 PM
EatnAsphalt's Avatar
Bike(s): 929
Rep: EatnAsphalt will become famous soon enough (70)
I've run into a strange problem with an 83 xr200. The bike was running just fine, clutch working normally. My gal stopped the bike in gear, holding the clutch in and idling. Less than half a minute later she lets out the clutch and nothing. The engine just revs, acts just like it's in neutral. Closer look shows that when the bike is in gear and the clutch is released, the chain jumps a little as you rev the engine but the bike doesn't move.
My first thought was the clutch wasn't disengaging. I checked the cable slack and everything is ok there. Next step was to remove the clutch. Once I got the side case off I discover a special tool is needed. But in the meantime I removed the 4 screws holding the clutch plates in to take the pressure off the clutch plates.
With the bike on the stand and in gear, should the clutch basket turn when the rear wheel is turned? The clutch is fully released (I took the small plate and clutch springs out).
If it's not the clutch, my only guess now is something in the transmission isn't fully engaged anymore.
Has anyone run into this type or problem before?
EatnAsphalt is offline
View EatnAsphalt's Profile View EatnAsphalt's Gallery Find More Posts by EatnAsphalt
Old 07-17-2005, 11:02 PM
G-Force Junkie's Avatar
Re: 83 XR200 Tranny/Clutch Problem
I had to split the cases on my '81 xr200 back in the day. That problem was it was hanging up in second gear. Problem was the slot in the shift drum had worn a burr and it was hard for the shift fork to slide properly. Not sure about y our problem, but it does sound clutch related. If it was something in the tranny, it wouldn not ahve let go just sitting there at a stop FWIW, i got a Clymers manual and Ithink that special tool to take the clutch off (looks like a 7/8 socket but has 4 prongs on it. I think I made it with an old socket and a grinder.)
Mike
G-Force Junkie is offline
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 3:38 AM.
