Honda Off-Road: Discussion of Honda Off-Road Vehicles, including Honda Dirt Bikes, Honda ATVs, Honda 4-Wheelers, and Honda Watercraft.
03-28-2007, 3:33 PM
Bike(s): CR 125 Posts: 4
| 2 stroke helpppppp i bought a 06 cr 125 in september. ive probably logged about 10 hours on it tops. how ever it seems to smoke and spew oil alot. im running 40:1 in it, and all of the carburator settings are what the book says it should be. i have heard that it could be a crank seal? what do you guys think i need your input pleaseeeee  |
03-28-2007, 4:19 PM
Bike(s): XRR 'tard, VFR Age: 30 Posts: 2,649
| Re: 2 stroke helpppppp By spewing oil do you mean out the exhaust? |
03-28-2007, 5:27 PM
| Re: 2 stroke helpppppp yeah its not like a flow of oil but it builds up fast on my fender and number plate |
03-28-2007, 5:37 PM
| Re: 2 stroke helpppppp A little medical history here
When did you first notice the problem? First hour, tenth hour, or somewhere in between? Does it seem to still be running fine or is it boggy feeling maybe? Is it fouling plugs? Does it start fine hot or cold? Or just one or the other? Is there anything you have tried that makes it seem any better or worse?
Somewhat unrelated but a general indicator of health on a dirtbike, how does the air filter look? |
03-28-2007, 5:42 PM
| Re: 2 stroke helpppppp when i first got it it was smokey so i figured the mixture was heavy for break in. fouled one plug on the gas that came with it. the bike hauls ass. starts up first kick. the thing thats got me scratchin my head is that i run the same gas in my 02 cr 125 and it runs clean. |
03-28-2007, 5:49 PM
| Re: 2 stroke helpppppp Doesn't sound like anything that I would worry about yet. My CR250 seemed overly smokey running on the same mix as my KDX so I just cut the mix back a little bit and it seems just fine. I would maybe quiz the dealer about what they usually see in normal break-in. I've never bought a brand new 2-stroke so I'm not sure what is normal during break-in. If it isn't fouling plugs then the mix isn't to far off. Have you pulled the current plug to see what it looks like. There is a fine art to reading the plug but if it looks overly "gooky" then you probably could cut the mix back a little bit.
Edit: if it is starting just fine hot and cold then I would say you haven't toasted the rings or anything like that. |
01-17-2009, 10:09 PM
Bike(s): 02' cbr954 Posts: 10
| Re: 2 stroke helpppppp my 02'cr 250 had oil drip onto swingarm and get on rear fender too. i tried alot of things too.carburation,settings,mixes. it never smoked when warmed up. what kinda fuel are you running? a had a bike that ran crapy down at low rpms. got ride of the ethanol and ran alot better. i ran avation fuel in my cr 250 . it had low lead in it too. |
01-17-2009, 10:15 PM
Bike(s): XX, RC51, '08 1000RR LE Posts: 4,540
| Re: 2 stroke helpppppp The first and last post was made on March 28, 2007; or almost two years ago. The OP also has not been back since that date; so he joined, made his four posts and has never been back since. |
