Go Back   Honda Motorcycles - FireBlades.org Forums > Honda Motorcycle Models > Honda Off-Road
Honda Off-Road: Discussion of Honda Off-Road Vehicles, including Honda Dirt Bikes, Honda ATVs, Honda 4-Wheelers, and Honda Watercraft.
Help!! broken off easy out (Huge Pics)
Old 12-07-2007, 7:42 PM
libretto's Avatar
Bike(s): 2001 CBR 929
Rep: libretto is on a distinguished road (10)
Send a message via AIM to libretto
Help!!!! Ok guys here is the deal I had a bolt head snap off in the frame for my CR500. It’s the bolt that holds the exhaust on to the frame down tube (see pictures). Here is the problem I drilled the bolt out and tried to use an easy out to get it out. Well the easy out broke off. Now I can’t drill it out anyone have any ideas how to solve this problem
Thanks in advance
I left them full sized so you could really see what i was talking about
http://i159.photobucket.com/albums/t...o/DSC_0712.jpg
http://i159.photobucket.com/albums/t...o/DSC_0711.jpg
http://i159.photobucket.com/albums/t...o/DSC_0708.jpg
libretto is offline
View libretto's Profile View libretto's Gallery Find More Posts by libretto My Map Location
Old 12-07-2007, 8:09 PM
Bike(s): 05 cbr 1000rr
Rep: Bryce Auten is on a distinguished road (16)
Re: Help!! broken off easy out (Huge Pics)
tack weld a bolt to it and use a nut to fasten it?
Bryce Auten is offline
View Bryce Auten's Profile View Bryce Auten's Gallery Find More Posts by Bryce Auten
Old 12-07-2007, 8:12 PM
Bike(s): 929rr , kawasaki ltd 450 , Yamaha YZ 125 .
Rep: THE JESTER is on a distinguished road (16)
Seen it happen before and done it myself.First step file it all down so that it is smooth then center punch a small hole in the middle to stop the drill bit skidding all over the place , then drill the whole lot out starting with a very small drill bit and go up in size as you go.While you are drilling apply lots of oil to cool and lube the drill bits or you will burn them out vey fast or worse yet snap them as well , once you got it all out re-tap a new thread you may need to go up a size of bolt at which point enlarge the hole on the mounting flange on the pipe.Rember take your time and don't rush it .Hope this helps you out it's worked for me a few times.
THE JESTER is offline
View THE JESTER's Profile View THE JESTER's Gallery Find More Posts by THE JESTER My Map Location
Old 12-08-2007, 12:25 AM
Bike(s): 900RR
Rep: robbied is on a distinguished road (10)
Used this method too and it works
robbied is offline
View robbied's Profile View robbied's Gallery Find More Posts by robbied
Old 12-08-2007, 1:40 AM
Bike(s): 2000 Fireblade
Rep: ucfmotorcycle1 will become famous soon enough (72)
There are also revers drill bits that turn counterclockwise. These are good for broken bolts as they drill out the bolts and turn them out at the same time.
ucfmotorcycle1 is offline
View ucfmotorcycle1's Profile View ucfmotorcycle1's Gallery Find More Posts by ucfmotorcycle1
Old 12-12-2008, 5:50 PM
Bike(s): honda 929 2001
Rep: stankosab is on a distinguished road (18)
as I understood you have a hard piece of easy out broken in the hole.
you can try to destroy it using a high speed drill like this:
Proxxon Trapano fresatore industriale IB-E da D'Amico forniture
(just to give you an idea oh wich kind of tool i mean)
using carbon metal (VIDIA) tools.
I was mould maker and we used that kind of tools to drill and mill hard metal.
or you can try to drill a hole on the opposite side of the tube and knock out the piece.
it seem insulting but extreem problem sometimes need extreem solution.
mine is just a suggestion
stankosab is offline
View stankosab's Profile View stankosab's Gallery Find More Posts by stankosab
Old 12-12-2008, 6:38 PM
Bike(s): '06 1000RR, '92 600F2
Rep: Weasle1000RR is on a distinguished road (47)
You sir, have the largest pictures in the land.
Weasle1000RR is offline
View Weasle1000RR's Profile View Weasle1000RR's Gallery Find More Posts by Weasle1000RR
Old 12-12-2008, 7:38 PM
AKA Canyon Whore...
jkobflys's Avatar
Bike(s): 2005 RC51
Rep: jkobflys is a jewel in the roughjkobflys is a jewel in the roughjkobflys is a jewel in the roughjkobflys is a jewel in the rough (334)
try a cobalt drill as carbide is strong it is too brittle and will brake easier,
low rps, should work if it all fails look up deburring shops in your area as they can burn out broken taps with a electric discharge machine, they should be able to burn out the easy out.
It is the mark of an educated mind to be able to entertain a thought without accepting it .
jkobflys is offline
View jkobflys's Profile View jkobflys's Gallery Find More Posts by jkobflys My Map Location
Old 01-04-2009, 10:05 PM
Bike(s): 929RR
Rep: Mustangous is on a distinguished road (34)
Thanks in advance
/DSC_0708.jpg[/IMG]
You cannot drill out an ez-out unless you have VERY expensive bits, i believe diamond bits. I had this happen in a cylinder head and had to get it dilled out on a mill with a $100 bit. Your best bet, like some one said is to get behind it(if possible) and knock it out, drill tiny holes around without breaking that bit and try picking it out. Not sure if you know how to weld, but another option would be to just grind off the welded threaded bung and reweld a new one.
Good luck, let us know how you make out!
Mustangous is offline
View Mustangous's Profile View Mustangous's Gallery Find More Posts by Mustangous
Old 01-04-2009, 10:10 PM
lanbrown's Avatar
Rep: lanbrown is a jewel in the roughlanbrown is a jewel in the roughlanbrown is a jewel in the rough (268)
For proplr that search, they will find more options. The OP posted his question over a year ago.
lanbrown is offline
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 5:39 AM.
