Help please 1984 XR 100 - Honda Motorcycles - FireBlades.org
Honda Off-Road Discussion of Honda Off-Road Vehicles, including Honda Dirt Bikes, Honda ATVs, Honda 4-Wheelers, and Honda Watercraft.
post #1 of 35 Old 07-05-2011, 6:11 PM Thread Starter
Hey all I just bought this dirt bike for my son. It has new carb new condesner new plug. When I kick it it turns over and after about 4 or 5 kicks. It seems to backfire sort of a phewwwwww sound from te exaust. It dosent start. Before I bought it it did start and idle for a bit but as soon as i gave it gas it stalled. I only paid 175 bucks for it but would love to get it running for him. Any ideas? There is spark from the plug. Motor turns over easily. Not sure where to go from here. Any suggestions would be appreciated.
Thanks
Mark
sammar is offline
post #2 of 35 Old 07-06-2011, 9:40 AM
Images: 2
Quoted: 2 Post(s)
Reputation Power: 227
Re: Help please 1984 XR 100
Thanks
Mark
What do you mean by "new carb" - brand new never had fuel in it?
Have you tried spraying starter fluid into the intake while kicking the engine over?
When you say the "motor turns over easily" do you mean it has little compression?
post #3 of 35 Old 07-06-2011, 11:04 AM Thread Starter
It seems to have proper compression I men the motor is not having any issues turning over. The carb has fuel in it though the PO did put a brand new carb on it. I have the old carb. Like I said if u kick it over 4 or 5 times it backfires.
Thanks
sammar is offline
post #4 of 35 Old 07-06-2011, 12:18 PM
Images: 2
Quoted: 2 Post(s)
Thanks
But you can definately feel the compression stroke?
If the new carb has been sitting for a few months with fuel in it though it'll be just as blocked as the new one that Honda put on it back in '84.
Backfiring could be cam or ignition timing.
Try starter fluid to rule out carburetion or spark as the problem.
post #5 of 35 Old 07-09-2011, 6:10 AM Thread Starter
Yes I can feel the compression stroke. I tried the starter fluid no go would not start. Still small backfire after kicking over a few times. There definately is spark from the plug. I looked at the timing marks and the flywheel is on the Tdc mark when the piston is at top of stroke.
sammar is offline
post #6 of 35 Old 07-09-2011, 8:05 AM
Images: 2
Quoted: 2 Post(s)
If you have spark then I think you're going to have to pop the lid off and check the cam timing and valve clearances and check the ignition timing.
The timing mark on the rotor won't move unless the rotor turns on the crank, can happen but not common.
post #7 of 35 Old 08-04-2013, 3:31 PM Thread Starter
so I know this has been a long time. havent had time work on the bike till recently. The carb that the PO had on there was the wrong one. I had the original carb and cleaned that out and got the bike running but the throttle is very unresponsive and it backfires alot i am trying to figure out what settings for the carb to get it running better can anyone help?
sammar is offline
post #8 of 35 Old 08-04-2013, 6:18 PM
Images: 1
Reputation Power: 33
Does the bike idle well but bangs out when hit throttle? Does it have aftermarket pipe? Idleair mixture screw should be around 1 1/2 turns out from seated.
Rubber side down, One wheel to the sky for those who we won't forget. R.I.P homies miss you.
900rrHonda is offline
post #9 of 35 Old 08-04-2013, 6:38 PM Thread Starter
I have tried the idler mixture screw in every possible position. Right now it will run and backfire sometimes with no response from the throttle. then after a while it will run at high revs. with choke in middle position it seems to have the right rpm and throttle works
sammar is offline
post #10 of 35 Old 08-04-2013, 11:56 PM
Images: 2
Quoted: 2 Post(s)
You have cleaned this carb recently?
post #11 of 35 Old 08-05-2013, 1:03 AM
Images: 1
He says he has or did before put back on in his post where stated other carb was wrong and he put stock on on after cleaning.
post #12 of 35 Old 08-05-2013, 1:04 AM
Images: 2
Quoted: 2 Post(s)
Sure, but that was a couple years ago ;-)
post #13 of 35 Old 08-05-2013, 2:21 AM
Images: 1
so I know this has been a long time. havent had time work on the bike till recently. The carb that the PO had on there was the wrong one. I had the original Carb and cleaned that out and got the bike running but the throttle is very unresponsive and it backfires alot i am trying to figure out what settings for the carb to get it running better can anyone help?
His first post after reviving the thread said he cleaned original carb and put in on
post #14 of 35 Old 08-05-2013, 2:40 AM
Images: 2
Quoted: 2 Post(s)
Yes, but he didn't say he'd done it _recently_, I'm trying to get confirmation is all.
post #15 of 35 Old 08-05-2013, 2:46 AM
Images: 1
Yea, was just Sayin he did say he cleaned old one before puttin back on. Prob wouldn't hurt for him to check it out again tho.
Go Back   Honda Motorcycles - FireBlades.org > Honda Motorcycle Models > Honda Off-Road
Human Verification
Help With a 1984 CR 500 mreed79 Honda Off-Road 3 05-24-2011 6:12 PM
1984 Honda CX 650 E Rickybeaver General Discussion 1 04-12-2011 7:22 AM
1984 V30 Magna ND4SPD Honda Cruisers 27 02-20-2009 5:50 PM
1984 cr500 daytona500 General Discussion 1 01-30-2009 3:58 PM
Van Halen 1984 Heavy-Dee Off-Topic 27 11-30-2005 9:46 AM
