brake res rubs fairing stay
05-04-2004, 1:09 PM
Bike(s): none Age: 51 Posts: 3,088
Rep:  (64) Rep Power: 10
| brake res rubs fairing stay just a tad when forks turned to the right lock. Anyone elses?
05-04-2004, 1:17 PM
Rep:   (137) Rep Power: 15
| Re: brake res rubs fairing stay I'm guessing you are using the stock clipons?
If so, just adjust the lever/mounting position, and this should alleviate the problem. |
05-04-2004, 1:28 PM
Bike(s): are cool. Posts: 2,325
Rep:  (10) Rep Power: 9
| Re: brake res rubs fairing stay Quote: |
Originally Posted by booth23 If so, just adjust the lever/mounting position, and this should alleviate the problem. | I can hear it now, "My wrists hurt, why?" |
05-04-2004, 2:29 PM
Bike(s): SV650S Posts: 5,710
| Re: brake res rubs fairing stay I had clearance problems when I had the fairing stay that came with the Ohlins damper. No problems I can remember with the stock clipons and fairing stay.
Is a paradigm worth 20 cents?
05-04-2004, 2:38 PM
Bike(s): '06 CBR1000RR, '06 CRF450X, '06 CRF100 Posts: 5,998
| Re: brake res rubs fairing stay Had the same problem after I adjusted my levers downward. Fixed it by tweaking (bending) the reservoir bracket a bit. |
05-04-2004, 3:16 PM
Bike(s): 2003 BabyRR Age: 31 Posts: 3,986
Originally Posted by Pete Had the same problem after I adjusted my levers downward. Fixed it by tweaking (bending) the reservoir bracket a bit. | Same here. I had my levers pointing down and Vortex clipons... Seemed the clutch and the brake would rub... |
05-04-2004, 7:17 PM
| Re: brake res rubs fairing stay I dont think the bike has been changed since new WRT the clipons etc. Either I never noticed it, or something has CHANGED... The clipons seem to be fairly symmetrical.
Im not going to lose any sleep over it though. Thanks all for the replies! |
05-04-2004, 10:50 PM
Bike(s): none again...so far... Age: 32 Posts: 4,011
Rep:  (87) Rep Power: 13
| Re: brake res rubs fairing stay Mine was like that too...straight from Honda...just a tweak, and we are good!  |
