| Re: NEED HELP W/THE TWIN!!! You have screws on it? You might have an early model I am not as familiar with. Regardless…the one that I had on the 929 is pretty much the same as the RC, so I will tell you what I do, if I need to do anything. There are three buttons to increase the richness levels of the fuel. Once you are able to move them around (and you can with the laptop I think) to make is more rich throughout the curve.
I personally have never seen this…I have put many exhaust systems on bikes, and never seen the pipes turn red….unless they pin it for a long time I imagine. Does this happen at idle? Does it only happen on the header? Also try it without the PCII or III or IIIr, whatever you are running. Lastly have you tried it with the 0 map in it?
