Changing the Clutch Fluid
Old 03-29-2005, 7:28 PM
Listen Johnny...
Crash's Avatar
Bike(s): 05 RC-51 - 03 KTM 525 SMC
Rep: Crash is a jewel in the roughCrash is a jewel in the roughCrash is a jewel in the roughCrash is a jewel in the rough (334)
Send a message via Yahoo to Crash
Okay, this may seem like a waste of bandwidth for some on this board, but I need a little assistance.
While I was putting on the new front sproket, I decided to change the clutch fluid as it was black. I have never had to deal with a hydro clutch before but it looks a lot like brake lines so I figured it couldn't be too bad. Well my question is this...
I can't seem to get the right pressure back into the system. I've bled the system a few times, but it feels like there is always air in it. My lever is so lose (How lose is it?) it seems like the clutch doesn't engage at all. Is there something I'm missing in the procedure? Do you pump the lever and continue to fill the system while still bleeding the air?
Thanks
Crash is offline
View Crash's Profile View Crash's Gallery Find More Posts by Crash
Old 03-29-2005, 7:40 PM
luvtolean's Avatar
Bike(s): Puch
Re: Changing the Clutch Fluid
Honestly, somehow I've never had to do it on a bike yet.
But on cars, hydro clutches can be a real bitch.
Just keep going, hydraulic systems are about as easy as they come. You have air in it, you need to get it out.
Sometimes taking a screwdriver handle and tapping around things, starting at the bottom, can help get the air bubbles moving.
luvtolean is offline
Old 03-29-2005, 8:50 PM
HondaGalToo's Avatar
I've bled my Ducati clutch. I had to use a MityVac to get things started. Then I bled it with the same procedure as brakes. From what I understand, hydraulic clutches are a pain to bleed. Keep at it, you've probably got air somewhere.
HondaGalToo is offline
Old 03-29-2005, 8:54 PM
CBRBob's Avatar
You bleed it just like brakes. Just get all the old fluid out of the master res. and refill it with new before you start. When you see clean fluid at the bleeder, your done. Keep trying it. Remember, the lever always comes to the grip.
CBRBob is offline
Old 03-29-2005, 10:19 PM
Back From the Ashes!!
TGZ13's Avatar
Like others have said... I used a zip tie holding the handle in while I taped the lines. Keep at it, eventually it will go away.. Just make sure to keep refilling that tiny ass res... I almost made mine get air back into the system cause I wasnt paying attention.
Good Luck
TGZ13 is offline
Old 03-30-2005, 12:57 AM
Bike(s): '04 RC51
Rep: JAMI6989 is on a distinguished road (12)
Send a message via AIM to JAMI6989 Send a message via Yahoo to JAMI6989
Try this:
Clutch speed bleeding
JAMI6989 is offline
View JAMI6989's Profile View JAMI6989's Gallery Find More Posts by JAMI6989
Old 03-30-2005, 11:37 AM
Listen Johnny...
Crash's Avatar
Thanks guys, I'll try the various things and hope I can figure this out. Now I know why I like cable systems
Crash is offline
Old 04-08-2005, 10:42 PM
saf
Bike(s): VTR SP-2 : 929RR (stunter) : CBR1000RR (racebike)
Rep: saf is on a distinguished road (13)
Send a message via MSN to saf
As Rob said. I have a big 60ml catheder syringe with a silicone line, drop that into the resiovoir and suck all the fluid out BUT leavea tad in the bottom. If you dont introduce air into the system (ie never let it go all the way down when bleeding) you wont have a problem . I dont see what the fuss is .... hydraulic brakes are EASY to bleed .
saf is offline
View saf's Profile View saf's Gallery Visit saf's homepage! Find More Posts by saf
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 1:36 AM.
