04-12-2005, 1:54 PM
#1 | | Compromise
Bike(s): '04 CBR1000RR, '84 Ascot, '02 RC51 Posts: 13,762
| Helmet cam on RC? I am thinking of hooking the helmet cam up for Grattan. I like the concept of putting it in a headlight but need to put the actual camera somewhere. Has anyone seen a setup before? Also down the road it will likely get track plastic so I loose the headlight any thoughts?
Thanks,
The Plotting Blue One
Reason: So people don't this is a how to
04-12-2005, 2:17 PM
| Re: Helmet cam on RC? Red Rider has a pretty sweet setup. I'm sure he can give you some pointers. |
04-12-2005, 2:40 PM
Bike(s): '01 CBR929 Age: 49 Posts: 7,832
| Re: Helmet cam on RC? Can't help you with an RC51, but the trunk on my 929 works great for storing the camcorder. I ran the wiring for both front and rear cams, the LANC switch, and the forward/rear selector switch under the fairings to the trunk. The camcorder is protected from vibrations with several layers of foam rubber. The setup works pretty well...
edit: I mounted the forward cam underneath the headlight on the fairing, and the rear cam on top of the rear cowling. Dual-Lok tape works well at holding them in place. Let me know if you have any questions, Sheep.
__________________ "It is better to post and risk reposting than to have never posted at all."
04-12-2005, 2:49 PM
#4 | | Compromise
| Re: Helmet cam on RC? Quote: |
Originally Posted by Red Rider Can't help you with an RC51, but the trunk on my 929 works great for storing the camcorder. I ran the wiring for both front and rear cams, the LANC switch, and the forward/rear selector switch under the fairings to the trunk. The camcorder is protected from vibrations with several layers of foam rubber. The setup works pretty well...
edit: I mounted the forward cam underneath the headlight on the fairing, and the rear cam on top of the rear cowling. Dual-Lok tape works well at holding them in place. Let me know if you have any questions, Sheep. | Thanks I got the huge truck also on the RC and some foam I saved
Any tips on wires around the triples, I assume wire tires and run over center with some slack for turning? I should even be able to do some road time practice by putting it in the bright boot.
04-12-2005, 2:57 PM
Originally Posted by sheepofblue Thanks I got the huge truck also on the RC and some foam I saved
Any tips on wires around the triples, I assume wire tires and run over center with some slack for turning? | I wasn't sure if the RC's trunk was big enough.
Just be careful when you run the wires that they don't get pinched or chafed and you should be fine. I tried to keep everything hidden by routing them behind the plastics and used a lot of zip ties. I'm going to play around with different mounting locations this year to get different POV's for some variety in footage (plus I want to see my suspension in action).
04-13-2005, 6:30 PM
Bike(s): 01 929 Age: 28 Posts: 3,191
Originally Posted by Red Rider I'm going to play around with different mounting locations this year to get different POV's for some variety in footage (plus I want to see my suspension in action). |
I shot a run through the Gap with Sheep's cam on my 929 last weekend and had it watching the front wheel... Pretty sweet! Ill post a bit of it up when I get it finished.
Chris |
04-13-2005, 9:50 PM
#7 | | Compromise
Originally Posted by NinerPilot I shot a run through the Gap with Sheep's cam on my 929 last weekend and had it watching the front wheel... Pretty sweet! Ill post a bit of it up when I get it finished.
Chris | Does it include the blue lights incident?
