Wooly Onboard computer project
10-13-2006, 8:10 PM
#151 | | Close encounter of the wool kind
Bike(s): '04 CBR1000RR, '84 Ascot, '02 RC51 Posts: 13,839
| Re: Wooly Onboard computer project Brown just arrived with the second part. This should keep me busy for a time. Notice the bottom of the GPS has a screw, I am considering mounting it in the nose if it can see through the track glass. The puck is also magnetic but that would not be a safe enough mount for track use.
Notice the attached photos this time
Send maple |
10-13-2006, 8:12 PM
#152 | | Meatarian
Bike(s): 01 R/B 929 Age: 28 Posts: 12,285
| Re: Wooly Onboard computer project Quote:
Originally Posted by sheepofblue Postal Clause just brought these goodies  The one on the left is a 2 axis gyro unit. The one on the right is a 3 dimension accelerometer. I will have to figure a mount for the accelerometer as it has no post holes (and I think it is a multi layer so I don't want to drill it). Notice the small size of these things, we truly live in an age of miracles. Time to get serious on case making and figuring mounting and such  |
you paid a quarter for them?
I guess they have to make them so cheap cause most people would have no
clue what to do with them.
10-13-2006, 9:31 PM
#153 | | Close encounter of the wool kind
clue what to do with them. | Ah but they sold them to me not you
Send maple |
10-16-2006, 8:35 PM
#154 | | Close encounter of the wool kind
| Re: Wooly Onboard computer project OK I am debating on where to put the case (and GPS)
Case
#1 under the seat
Pros higher degree of protection from subframe, right by battery
Cons not a bunch of space and I put the cam in there now
#2 fairing nose
Pros more space, power from headlight circuit
Cons no metal protection in case of crash
GPS
#1 in nose
Not sure it can get adequate coverage through te fiberglass but it would be easy to drill the glass and mount it
#2 on the tail behind passeger sheep
Got to drill the ABS but should be OK. However there is a puck on top of the bike and it is exposed in a crash. Chin rest for passenger sheep
Both locations are easy as I have about 5' of cabling to work with.
Any opinions or ideas?
Send maple |
10-16-2006, 9:41 PM
#155 |
Bike(s): GSXR Stunt Bike Age: 39 Posts: 4,200
| Re: Wooly Onboard computer project #3 Hookers |
10-16-2006, 10:01 PM
#156 | | Close encounter of the wool kind
Originally Posted by Hammer #3 Hookers |  from the sheep tire service
Send maple |
10-16-2006, 10:03 PM
#157 |
Originally Posted by sheepofblue  from the sheep tire service | The pay was shitty anyhow. |
10-16-2006, 10:11 PM
#158 | | Close encounter of the wool kind
Originally Posted by Hammer The pay was shitty anyhow. |  pay  it is all free to non-whoremongers
Send maple |
10-16-2006, 10:42 PM
#159 | | I slide good in the wet
Bike(s): 04 Fireblade Posts: 639
| Re: Wooly Onboard computer project It seems that location is going to be very important for the accelerometer. Even in a car, they are best mounted where the least amount of movement happens. Seems tough on a performance bike. |
10-16-2006, 10:45 PM
#160 | | Close encounter of the wool kind
Originally Posted by clutchslip It seems that location is going to be very important for the accelerometer. Even in a car, they are best mounted where the least amount of movement happens. Seems tough on a performance bike. | Good point. I was going to put it in the case with the computer. Considered mounting it on a foam or silicone to damp some vibration from the silky smooth RC engine  It would be easier to fasten the case in the front...
Send maple |
12-12-2006, 1:30 AM
#161 | | I slide good in the wet
| Re: Wooly Onboard computer project What the heck is going on with this stuff?
I might be buried before you get done with this thing.  |
12-12-2006, 9:11 AM
#162 | | Close encounter of the wool kind
Originally Posted by clutchslip What the heck is going on with this stuff?
I might be buried before you get done with this thing.  | Side tracked on the DVD  I plan on ramping up this week when I am done with Christmas presents.
Send maple |
