12-01-2005, 7:37 PM
#1 | | Send Maple Clarice
Bike(s): '04 CBR1000RR, '84 Ascot, '02 RC51 Posts: 13,810
| CF Lower It has begun  Got the lower now to start ordering more. The biggest question I have though is the heat sheild stuff Opp recommends. Anyone use it? Is it necessary?
Yes I know it needs cleaning, just pulled from the packing peanuts. |
12-01-2005, 8:31 PM
Bike(s): Puch Posts: 14,391
| Re: CF Lower If they recommend it, I'd definately use it. |
12-01-2005, 8:33 PM
#3 | | Send Maple Clarice
| Re: CF Lower Quote: |
Originally Posted by luvtolean If they recommend it, I'd definately use it. |  thanks I was expecting a ripping (everyone says I will regret using CF) and it took a second to remember I had asked a question  |
12-01-2005, 8:35 PM
| Re: CF Lower You'll only regret it if you crash.
Otherwise, it's my kinda bling, functionally superior (in this case lighter) and looks cool.
I just said to nhff in a PM that carbon and Ti are to me, what diamonds and platinum are to most women.  |
12-01-2005, 8:41 PM
#5 | | Send Maple Clarice
| Re: CF Lower Yep I was planning an ART CF undertail and maybe a hugger (not sure if this is a good idea though due to clearance issues) |
12-01-2005, 8:45 PM
#6 | | Just repeating what ever I hear...
Bike(s): 2004 GSXR 600 Age: 31 Posts: 6,319
Originally Posted by luvtolean I just said to nhff in a PM that carbon and Ti are to me, what diamonds and platinum are to most women.  | I like that. I might have to start using it.
HD |
12-01-2005, 8:57 PM
Originally Posted by sheepofblue Yep I was planning an ART CF undertail and maybe a hugger (not sure if this is a good idea though due to clearance issues) | First off, if you are referring to the fibreglass cloth with the aluminum foil backing, it works great and will prevent any discoloration or burn through.
Secondly, what clearance issues are you talking about with the tail liner and rear fender? I have both and there are no clearance issues at all. |
12-01-2005, 9:04 PM
#8 | | Send Maple Clarice
Originally Posted by abtech First off, if you are referring to the fibreglass cloth with the aluminum foil backing, it works great and will prevent any discoloration or burn through.
Secondly, what clearance issues are you talking about with the tail liner and rear fender? I have both and there are no clearance issues at all. | Thanks! I had just heard that sometimes re-gearing and undertails did not mix well (with 190s) So I was a bit hesitant on the hugger. The undertail I am more waffling on brand (ART, Opp or other). I can get a steal on an ART and the fenders seem decent but no one seems to have much to say on the undertray. There are a couple of other brands that seem to get good reviews also.
The heat they have a whole kit on Opp. Seems a bit pricey though  |
12-01-2005, 9:07 PM
| Re: CF Lower Uh yeah, that's a bunch of money for no "custom" anything.
I don't think you want to wrap your headers. Just get the stuff abtech was talking about. Sometimes it even has adhesive on the backside so you cut it to shape and just stick it on. |
12-01-2005, 9:11 PM
#10 | | Send Maple Clarice
Originally Posted by luvtolean Uh yeah, that's a bunch of money for no "custom" anything.
I don't think you want to wrap your headers. Just get the stuff abtech was talking about. Sometimes it even has adhesive on the backside so you cut it to shape and just stick it on. | Yep my thought also. Plus I can likely get header tape here in town (need some for the rear header anyway (to save the shock and eliminate IR noise for my planned suspension sensor  ) |
12-01-2005, 9:14 PM
Bike(s): 2001 929 Age: 33 Posts: 4,720
Originally Posted by sheepofblue It has begun  Got the lower now to start ordering more. The biggest question I have though is the heat sheild stuff Opp recommends. Anyone use it? Is it necessary?
Yes I know it needs cleaning, just pulled from the packing peanuts. | How's the fit & finish? |
12-01-2005, 9:15 PM
#12 | | Resident Cockhole
Bike(s): 2000 CBR929RR, 2001 RC51 Age: 32 Posts: 807
Originally Posted by sheepofblue The heat they have a whole kit on Opp. Seems a bit pricey though  | From the site: Installation Instructions - It's Fun and Easy!
That's a first! I can't imagine wrapping the headers would be fun or easy...  Maybe I could con someone in to it. "Come on! It's fun AND easy! The instructions say so!" |
12-01-2005, 9:20 PM
#13 |
| Re: CF Lower Header wrap fun?
I should've read that.
Take your arms, immerse them in the finest pool of fiberglass shavings you can find, and then tell me if wrapping headers with thermal tape is fun.
IT SUCKS!
And it thermally fatigues the crap out of your exhaust system. |
12-01-2005, 9:21 PM
#14 | | Send Maple Clarice
Originally Posted by nhfirefighter13 How's the fit & finish? | Seems decent when I get a glass upper it should be easier to tell though A bit of pin holing but not to bad (figure on the bike with wax? and you won't even see it) decent flex and the form looks good but that will tell more when I fit it. On the  side there is not indents for the screws so why didn't they go ahead and drill so it was ready
Now all I need is to provide positive feedback to the seller via paypal  |
12-01-2005, 9:23 PM
#15 | | Send Maple Clarice
IT SUCKS!
And it thermally fatigues the crap out of your exhaust system. | Another reason rather than wrapping the rear I was dreaming up a CF shield that shields heat on the shock side but open on the other. Kind of a heat reflector (or lens) |
12-02-2005, 7:55 AM
#16 |
| Re: CF Lower I believe the rear header/shock heat issue isn't really an issue. I can touch anywhere on the shock after 10 laps and although warm, it isn't even close to the temp of the header. I have the Pyramid rear fender and run a 190 without any problem at all. BTW, I made my undertail unit out of sheet teflon with Dzus attachments. The only reason I use an undertail is to protect all the electronics since I have a "slightly" modified rear subframe. |
12-02-2005, 8:10 AM
#17 |
Bike(s): '99 VFR800 W/RC51 usd forks, brakes Posts: 111
Rep:  (76) Rep Power: 3
| Re: CF Lower |
12-02-2005, 8:21 AM
#18 | | Send Maple Clarice
Originally Posted by abtech I believe the rear header/shock heat issue isn't really an issue. I can touch anywhere on the shock after 10 laps and although warm, it isn't even close to the temp of the header. I have the Pyramid rear fender and run a 190 without any problem at all. BTW, I made my undertail unit out of sheet teflon with Dzus attachments. The only reason I use an undertail is to protect all the electronics since I have a "slightly" modified rear subframe. |  the only other reason is if you plan to use IR sensors to monitor travel
The other huge difference is for now I still want the ability to go back to road legal at times. While it spent all of last summer in track trim in a couple of weeks Mom and Dad are moving back here and I think there is a chance of riding some with Dad this summer if I have 2 bikes
Thanks veefer800canuck but it had a front fender when I bought it. So the fender and lower are now here.
