Running Hot
Old 02-19-2006, 6:04 PM
Bike(s): rc51
Rep: timgo is on a distinguished road (10)
Running Hot
Recently purchased 04 RC 51. Running at FWY speed to PCH approx. 72 degrees the bike was at 230 to 240. Running at slower speeds the temp. dropped to 215 to 230. On the way back in the evening the temp. went back up to 240 and on the last mile home hit 250 with the warning light comming on.
The water level is good in the radiator.
I know that this bike runs hot but has anyone experienced this problem.
timgo is offline
View timgo's Profile View timgo's Gallery Find More Posts by timgo
Old 02-19-2006, 6:09 PM
ozthis's Avatar
Bike(s): 04 rc51, 07 KTM 690sm
Rep: ozthis will become famous soon enough (52)
Re: Running Hot
that is too hot...my rc runs hot but the fans kick on at 220 and have no problems cooling it down some. I would check too see if your fans are kicking on or check your coolant level and mix and make sure you have a working thermostat
ozthis is online now
View ozthis's Profile View ozthis's Gallery Find More Posts by ozthis
Old 02-19-2006, 6:23 PM
Resident Cockhole
southpark460's Avatar
Bike(s): 2000 CBR929RR, 2001 RC51
Rep: southpark460 has a spectacular aura aboutsouthpark460 has a spectacular aura aboutsouthpark460 has a spectacular aura about (206)
Send a message via AIM to southpark460 Send a message via Yahoo to southpark460
Re: Running Hot
Sounds like you may have an air bubble in the line somewhere. Try burping her. Just throw her over your shoulder and tap her until she spits up all over your back. Or try searching for the "proper" method.
southpark460 is offline
View southpark460's Profile View southpark460's Gallery Find More Posts by southpark460
Old 02-19-2006, 8:52 PM
Red Rider's Avatar
Bike(s): '01 CBR929
Re: Running Hot
Something's not right if your temps drop at slow speeds and rise at freeway speeds.
Red Rider is offline
Old 02-24-2006, 9:46 PM
Bike(s): Honda RC 51
Rep: shadoxkila is on a distinguished road (10)
Re: Running Hot
i have an RC and last year I hit a pot hole and cracked the weld that held my radiator to the frame it didn't leak or overheat when i let it sit there and run but when u took it out the temp sky rocketed to 240-250 withno fan kicking on. The crack was probably a little larger than a pin so you'd be surprised how small a crack can screw your radiator up. I eventually just replaced the radiator and that solved everything....
shadoxkila is offline
View shadoxkila's Profile View shadoxkila's Gallery Find More Posts by shadoxkila
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 9:02 PM.
