Help with some measurements front wheel
Old 03-05-2006, 11:35 PM
Bike(s): VFR800R1 / CBR1000RR
Rep: zRoYz is on a distinguished road (10)
Mt first post is a question sorry for that
I don't own a RC51 but my VFR750 is in the process of fitting RC51 forks.
I'm going to use VFR front wheel & just change out wheel bearings to 22mm & make new spacers (disks will need diff offset, but can get custom made if no cross match).
I need to know RC51 front wheel spacer lengths as follows:
1. Left spacer length.
2. Right spacer length.
3. Wheel bearing outside to wheel bearing outside length (if just internal wheel spacer length that will do).
I need these lengths to compair with VFR wheel & adjust lengths to suit setup, I also know it needs to be spot on so measurements need to be +/- .05mm (this gives max tol .1mm)
I will post pic when complete, at present forks fitted just need to fit wheel & work out what clip-ons I want to use.
zRoYz is offline
View zRoYz's Profile View zRoYz's Gallery Find More Posts by zRoYz
Old 03-05-2006, 11:36 PM
ConqSoft's Avatar
Bike(s): 2007 Honda ST1300
Re: Help with some measurements front wheel
Did you see this? http://www.fireblades.org/forums/int...front-end.html
My Blog
GPS Discussion Forum
ConqSoft is offline
Old 03-05-2006, 11:47 PM
Gee that was quick
Yes have read all there build ups on VFRD forum, place that started me on this project.
I also hope to be building up 954 track bike which is next project so info here will be great
zRoYz is offline
Old 03-07-2006, 4:08 AM
Found out the RC51 forks are 214mm between fork centre, I can work everything out from that
zRoYz is offline
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 10:02 AM.
