Fork Oil level in forks
Old 04-08-2006, 4:19 AM
Bike(s): VFR800R1 / CBR1000RR
Rep: zRoYz is on a distinguished road (10)
Hi, can anybody tell me fork oil level in forks or volume (level would be best).
Other question is oil level measured with out spring & fork full compression?
zRoYz is offline
View zRoYz's Profile View zRoYz's Gallery Find More Posts by zRoYz
Old 04-08-2006, 7:27 AM
abtech's Avatar
Bike(s): 2007 RC51
Re: Fork Oil level in forks
Fow which bike? Your avatar says VFR, but this is posted in the RC51 forum? The correct procedure is to measure from the top of the tube to the top of the oil with the springs out and the tubes collapsed.
abtech is offline
Old 04-08-2006, 7:55 AM
The bike is a VFR, it just has RC51 front end
Do you know that measurement, that's what I'm after, have full workshop manual for VTEC, bit of a waste to buy one just to find out fork oil level for RC51 forks.
zRoYz is offline
Old 04-08-2006, 8:08 AM
abtech's Avatar
Bike(s): 2007 RC51
Okay, what year (or model SP1 or SP2) are the forks?
The manual for the SP1 states 135 mm. I am running 105 mm of Showa 5 wt racing fluid on mine, but that's for the track.
abtech is offline
Old 04-08-2006, 9:44 AM
Thanks very much for that, they are SP1
(decreased your air gap to increase dampening more than your ajustments could do?)
Just out of interest is standard 5 wt, the VFR has a few extra kgs so going to start with standard setup & work from there (VFR standard forks are 43mm & use 10 wt & was using 0.9 springs)
zRoYz is offline
Old 04-08-2006, 11:37 AM
abtech's Avatar
Bike(s): 2007 RC51
Nope, damping is spot on, just helps to keep the nosedive to a minimum without having to crank in a bunch of compression damping. The 5 weight allows the forks to react faster to smaller bumps. The manual recommends Pro Honda Suspension Fluid SS-8.
abtech is offline
Old 07-14-2006, 8:05 AM
I thought a prob should post pic seeing you helped me out
zRoYz is offline
Old 07-14-2006, 10:35 AM
abtech's Avatar
Bike(s): 2007 RC51
Very nice
abtech is offline
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 9:07 AM.
