04-20-2006, 8:00 PM
#1 | | Compromise
Bike(s): '04 CBR1000RR, '84 Ascot, '02 RC51 Posts: 13,776
| Scott's Damper install? Warning no S***p are mentioned in this post
So is it best to remove the nut on the upper triple with the bike on a stands, front stand only or on the ground in a normal manner to install my Scott's damper?
04-20-2006, 8:06 PM
Bike(s): GSXR Stunt Bike Age: 39 Posts: 4,200
| Re: Scott's Damper install? Just leave it on the ground, unscrew the nut and replace with the new nut that came in the package. |
04-20-2006, 8:07 PM
#3 | | Resigned to pursue other interests.
| Re: Scott's Damper install? Quote: |
Originally Posted by Hammer Just leave it on the ground, unscrew the nut and replace with the new nut that came in the package. | |
04-20-2006, 8:08 PM
#4 | | Das Ende ist hier
Bike(s): One Posts: 2,705
| Re: Scott's Damper install? If you're only taking the steering stem nut off, it shouldn't matter as the lower will still be firmly attached to the forks and supporting the weight of the bike.
[edit] Looks like we all read this simultaneously. |
04-20-2006, 8:14 PM
| Re: Scott's Damper install? Mock it up to check for fitment issues first. Then pull the allen screws back out and then loctite them in place.
May save you some headaches. |
04-20-2006, 8:14 PM
Bike(s): 04 600RR, 03 XR50, 05 TC250 Age: 65 Posts: 4,668
| Re: Scott's Damper install? It's best to remove the nut on the seat. |
04-20-2006, 8:15 PM
#7 | | Compromise
| Re: Scott's Damper install? Thanks
