No spark at the plugs
Old 04-22-2006, 2:51 AM
Bike(s): Matt Black SP-1
Rep: Wizard is on a distinguished road (10)
Hi people,
I am having a problem with my SP-1 (Austalian model of the RC51)
I'm not getting any spark on one cylinder and inly i tiny little spark on the other, not enought to see but i can feel it when i touch the plug and the block.
I checked and there isnt any voltage getting to the rear coil either.
Any idea what could cause this will be greatly appreciated. Also if anyone has a wiring diagram or knows where I can get one that would be awesome.
Thanks.
Wizard is offline
View Wizard's Profile View Wizard's Gallery Find More Posts by Wizard
Old 04-22-2006, 8:03 AM
Resident Cockhole
southpark460's Avatar
Bike(s): 2000 CBR929RR, 2001 RC51
Rep: southpark460 has a spectacular aura aboutsouthpark460 has a spectacular aura aboutsouthpark460 has a spectacular aura about (206)
Send a message via AIM to southpark460 Send a message via Yahoo to southpark460
Re: No spark at the plugs
Do you have a service manual? There's a nice troubleshooting tree in there. I would also check all the grounds and battery connections to make sure they're tight. Has anything changed on the bike prior to this problem occurring?
Edit: Could be battery too... The battery can show 12V at idle, but not have enough amps to start the system.
southpark460 is offline
View southpark460's Profile View southpark460's Gallery Find More Posts by southpark460
Old 04-22-2006, 12:27 PM
Bike(s): 01'RC51, 00'CBR600F4, 89CB-1, 99SV650, DRZ400SM
Rep: HRC NICK 11 will become famous soon enough (76)
Check the Kill switch after a fall I have seen them do strange things, and also have seen them just wear out.
also could be one of the 2 relays controled by the tip sensor or the tip sensor itself, a good check for that is to see if the uel pump comes on when you turn on the key.
HRC NICK 11 is offline
View HRC NICK 11's Profile View HRC NICK 11's Gallery Find More Posts by HRC NICK 11 My Map Location
Old 04-23-2006, 6:26 AM
The battery isnt the prob cos it's able to turn the bike over plenty fast and I have also tried jump starting it from my car (It turned over even faster then usual) and still nothing.
As for the kill switch/stand/tilt sensors, the fuel pump still kickes in when I turn the bike on so can't be then cos by looking at the wiring diagram the pump wouldnt run without them working.
I have a feeling its the CDI unit you I'm going to have a look around for a new/used one tomorrow and hopefully that'll fix my problems.
Thanks guys.
Wizard is offline
Old 04-23-2006, 8:11 AM
Custom900's Avatar
Bike(s): The REAL KING - Hayabusa
Rep: Custom900 has a spectacular aura aboutCustom900 has a spectacular aura aboutCustom900 has a spectacular aura about (231)
Send a message via AIM to Custom900
It sounds as if you have a coil out.
Custom900 is offline
View Custom900's Profile View Custom900's Gallery Find More Posts by Custom900
Old 04-23-2006, 8:33 AM
Resident Cockhole
It'll run on one cylinder. Don't ask how I know...
Old 04-24-2006, 4:17 AM
I FOUND THE PROBLEM!!!
CDI Unit had a problem, I brought a second hand unit from a wreaker plugged it in and she fired up almost first go, expect the battery was too flat to turn her over so a quick jump start and off she roared!!
I think it was ccaused by the CDI Unit hitting the frame due to the bottom holder mount being broken from the frame.
So for future reference if your bike seems to drop a cylinder check out you CDI Unit, Mounted on the right hand side on the sub frame.
Wizard is offline
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 1:51 PM.
