05-17-2006, 12:07 AM
Bike(s): 2004 RVT1000R RC 51 Posts: 9
| Hot Bodies Undertail Here is my problem I gust recieved my undertail (SBK with LEDs). I have wired everything up and now my turnsignals are blinking like there is a blown bulb, what kind of resistors do I need.  |
06-01-2006, 5:37 PM
Bike(s): 04 rc51 sp2 Age: 45 Posts: 2
| Re: Hot Bodies Undertail Quote: |
Originally Posted by 04RC51 Here is my problem I gust recieved my undertail (SBK with LEDs). I have wired everything up and now my turnsignals are blinking like there is a blown bulb, what kind of resistors do I need.  |  just change your bulbs to a higher wattage . |
06-01-2006, 6:26 PM
Bike(s): 07' BMW GSAdv, '06 GSX-R750,'03 VTX1800R,'95VFR750 Age: 37 Posts: 1,787
| Re: Hot Bodies Undertail |
06-02-2006, 8:32 AM
Bike(s): CBR1100XX, CBR954, RC51 Posts: 427
Rep:  (24) Rep Power: 6
Originally Posted by 04RC51 Here is my problem I gust recieved my undertail (SBK with LEDs). I have wired everything up and now my turnsignals are blinking like there is a blown bulb, what kind of resistors do I need.  | I am thinking about installing an undertail. What was your experience installing yours? |
06-03-2006, 11:19 AM
#5 | | You could melt all this stuff!
Bike(s): 2004 Honda RC51 Age: 35 Posts: 56
Rep:  (31) Rep Power: 3
| Re: Hot Bodies Undertail I was just looking at that same one. How did it go? How long did it take? The only reason I haven't put on the undertail yet is because I was worried about the access to the trunk lock. Is it a pain in the a$$? |
06-03-2006, 1:38 PM
Originally Posted by RktRC I was just looking at that same one. How did it go? How long did it take? The only reason I haven't put on the undertail yet is because I was worried about the access to the trunk lock. Is it a pain in the a$$? | There are some pics of my Dussault install on this thread which will give you some idea about what you're in for. I don't know about the trunk lock on the Hot Bodies, but the Dussault was no problem. https://www.fireblades.org/forums/ho...ight=UNDERTAIL |
06-04-2006, 12:40 AM
Bike(s): RC51 Posts: 44
| Re: Hot Bodies Undertail When I installed my Watsen Designs LED fronts, I used two 5watt 15Ohm in parrallel. They really slowed the flash rate down.
Good Luck |
06-07-2006, 9:29 PM
| Re: Hot Bodies Undertail I found a place online that sells turnsignal relays that are made for LEDs. As far as the installlation of the undertail it was straightforward and not hard at all, the lock is not a problem it still works like stock  |
