FI light question or should I say problem!!!
09-11-2006, 11:41 AM
Bike(s): 2003 rc51 Posts: 15
| FI light question or should I say problem!!! I have a FI code flashing. One long and nine short. Now I have been redoing my bike since my wreck, and installed a soft rev lim., well my body did why I was doing something else, well he put it in the 3rd hole instead of the forth. Didnt notice it till we already tried starting it, now she wont run. Has this happend to anyone else. I have put new plugs in since and everything looks right, but cant fiqure why she isnt running. Remaped pcIIIr. Can anyone help?  |
09-11-2006, 11:42 AM
#2 | | Resigned to pursue other interests.
| Re: FI light question or should I say problem!!! |
09-11-2006, 11:52 AM
| Re: FI light question or should I say problem!!! Do I count the long flash as one or just the short ones. Has this ever happened to you, and is it a easy fix. How do you do it? |
09-11-2006, 11:54 AM
#4 | | Resigned to pursue other interests.
| Re: FI light question or should I say problem!!! If you look at the top of the first attachment in that thread, it explains the blinks. If you have one long, and 9 short, that would be 19. Look on page two for what 19 is. |
09-11-2006, 11:56 AM
| Re: FI light question or should I say problem!!! So nine blinks say the engine operates normally, but it dosnt. |
#6 | | Resigned to pursue other interests.
| Re: FI light question or should I say problem!!! Look at 19, it says the engine won't start. |
09-11-2006, 11:57 AM
| Re: FI light question or should I say problem!!! Where is the ignition pulse generator connector, or wire ? |
09-11-2006, 11:58 AM
#8 | | Resigned to pursue other interests.
| Re: FI light question or should I say problem!!! You'll need to purchase a service manual to fully debug it, most likely. This seems to be the best place to order. |
09-11-2006, 12:01 PM
| Re: FI light question or should I say problem!!! Can you send some pics, to help a brother out. Like to get back on the road. It will probably take a week to get manual |
09-11-2006, 7:12 PM
| HEY, check this out.... I had a fi code19. I reset the code, checked pulse generator code, had good conection and ohms. Still didnt start. What the hell am I doing wrong?  |
09-11-2006, 7:18 PM
| retreiving codes? How do I retreive a code? Somebody said I need to retreive the code I am getting. Its a 19. |
09-11-2006, 8:12 PM
#12 | | Resigned to pursue other interests.
| Re: FI light question or should I say problem!!! (Please don't start three threads for the same subject.)
You've already "retrieved" the code by looking up what it means. Now you just need to fix the issue, or take it to a shop to have it fixed. |
09-12-2006, 8:51 AM
#13 |
| Re: FI light question or should I say problem!!! thanks for your help.. wish me luck  |
09-25-2006, 11:54 AM
#14 |
| Re: FI light question or should I say problem!!! Just cant figure it out. I have erased the codes and checked everything. Still will not start. Would the codes come back even though it will not start. Because I am not getting any codes now.  |
#15 |
| Re: FI light question or should I say problem!!! I just want my bike back  |
