Clutch question
Old 09-14-2006, 11:05 AM
Bike(s): 01 rc51 coming back 2 life
Rep: jacksonrc51 is on a distinguished road (10)
Clutch question
Anybody know what would make my clutch act up after I ride, stop, & start it back up? It's totally fades and won't work until I bleed the slave cylinder. I neve see any air in the line, but it starts to work fine after that. I have a Brembo master cylinder and braided lines.Everything else is stock (I think). One guy suggested that the lines may be conducting too much heat and overheating the fluid. What y'all think?
jacksonrc51 is offline
View jacksonrc51's Profile View jacksonrc51's Gallery Find More Posts by jacksonrc51
Old 09-14-2006, 11:42 AM
Compromise
sheepofblue's Avatar
Rep: sheepofblue has much to be proud ofsheepofblue has much to be proud ofsheepofblue has much to be proud ofsheepofblue has much to be proud ofsheepofblue has much to be proud ofsheepofblue has much to be proud ofsheepofblue has much to be proud ofsheepofblue has much to be proud ofsheepofblue has much to be proud ofsheepofblue has much to be proud of (1354)
Re: Clutch question
Either you are not getting all the air out or you have a bad crush washer. If you have taken the line off and reused the crush washers (especially more than once) it is likely the second.
sheepofblue is online now
Old 09-14-2006, 1:06 PM
Re: Clutch question
Thanks for the advice i'll replace the washers. Couldn't hurt right? Plus, it gives me something to do.
Old 09-16-2006, 4:24 PM
Rigor's Avatar
Bike(s): 2003 Honda RC51, 1975 Suzuki GT550
Rep: Rigor is on a distinguished road (37)
Re: Clutch question
I'd also take a look at how old your fluid is. Brake fluid (that you use for your clutch) is Hydroscopic, and attracts moisture. If it's old fluid, it may be contaminated and fresh fluid, (dry=new) might solve the problem.
Air in the system sounds as if it's the problem, though, based on what you're saying.
If it was due to "overheating", you'd have to have an extensive amount of heat in the line, and/or a sh*t load of moisture to cause a fade-type situation.
The feedback pressure from a clutch isn't that critical or harsh to get that complicated.
Replace the fluid and see what happens. Bleed it good too. Nice and sloooooow.............
Rigor is offline
View Rigor's Profile View Rigor's Gallery Find More Posts by Rigor
Old 09-17-2006, 9:08 AM
Bike(s): '05 RC51
Rep: RC51Ophile is on a distinguished road (10)
Re: Clutch question
You may have a bad "O-ring" on the slave cylinder piston. Hard to see when it leaks into the C/S sprocket area.
RC51Ophile is offline
View RC51Ophile's Profile View RC51Ophile's Gallery Find More Posts by RC51Ophile
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 10:12 PM.
