Power (or lack of) Commander Question
Old 10-31-2006, 8:18 AM
jjj0923's Avatar
Bike(s): Ducatis & Hondas
Rep: jjj0923 will become famous soon enough (54)
Oh - the wonderful state of Maryland. I finally got around to taking my 03' RC51 in for Inspection and they (as usual) went out of their way to fail me for every possible reason.
In any event, I won't whine - I'll just pull a wheelie when I leave after taking it back in for re-inspection.
That's not why I'm posting...
I had to install lights over the license plate because the fender eliminator kit does not cast any light on the license plate and that's a problem in Maryland.
So, I found some nice little lights and installed them. In the process of installing them I blew a fuse and replaced the fuse.
Now, my bike won't start. I pulled out the service guide and found that the blinking FI lights show that my air intake sensor is not functioning properly. But that's not the reason she won't start, the sensor is just not plugged in anywhere and I can't figure out where it's supposed to be plugged in. I checked the wire colors to identufy it. It's buried in the wires on the left side of the headlight cover and the plug is gray in color and has two wires going into it...where does it get connected? I think it's actually been this way since I bought the bike.
Now - about my Power Commander. After pulling my hair out for a few hours checking wires over the weekend it dawned on me last night driving home that the problem may be the power commander. The bike turns over, but won't start.
I checked the power commander after turning on the ignition and none of the lights on the power commander come on. I guess I'll have to check the wires to the power commander and see what's up with that.
What lights should display on the power commander when you turn the ignition on???
thanks in advance.
Jeff
Retired AMA Ducati Superbike Racer
jjj0923 is offline
View jjj0923's Profile View jjj0923's Gallery Visit jjj0923's homepage! Find More Posts by jjj0923
Old 10-31-2006, 10:16 AM
Red Rider's Avatar
Bike(s): '01 CBR929
Re: Power (or lack of) Commander Question
Stating the obvious here...disconnect the Power Commander to see if that's the problem.
Red Rider is offline
Old 10-31-2006, 11:02 AM
jjj0923's Avatar
how about that gray connector up front?
jjj0923 is offline
Old 11-01-2006, 2:01 AM
jjj0923's Avatar
it turned out to be a faulty ground wire as a result of re-arranging some wire under the seat to make thing a little more orderl.y - my fault of course... strange part is that lights installed over license plate works properly even though they were connected to the same "supposed" grounding point. In any event - all is well and I just slapped a 46 tooth sprocket on the back with a 15 up front - it's now a real wheelie king...
jjj0923 is offline
Old 11-03-2006, 9:34 AM
Rigor's Avatar
Bike(s): 2003 Honda RC51, 1975 Suzuki GT550
Rep: Rigor is on a distinguished road (37)
FYI:
DO NOT use a frame ground for your power commander. Ground it to the neg side of the battery........
Rigor is offline
View Rigor's Profile View Rigor's Gallery Find More Posts by Rigor
Old 11-05-2006, 1:58 AM
jjj0923's Avatar
Originally Posted by Rigor View Post
FYI:
thanks - I do not.. it's grounded to the battery
jjj0923 is offline
Old 11-17-2006, 11:32 AM
Bike(s): 2000 RC51
Rep: chawness is on a distinguished road (23)
Did the 15/46 fit under the stock chain??
chawness is offline
View chawness's Profile View chawness's Gallery Find More Posts by chawness
Old 11-17-2006, 11:35 AM
jjj0923's Avatar
I switched to a 520 when I changed sprockets.
jjj0923 is offline
Old 11-18-2006, 9:45 AM
Bike(s): 2001 RC51
Rep: kelleyj is an unknown quantity at this point (5)
FYI:
good to know. im ordering my PC prolly monday morning.
kelleyj is offline
View kelleyj's Profile View kelleyj's Gallery Find More Posts by kelleyj
Old 04-11-2007, 12:23 AM
Bike(s): '03 rc51 pair, flapper, cam gear mods jardine hi's
Rep: navymills is on a distinguished road (10)
I don't know if you figured it out yet or not, but the it sounds like your map sensor is the plug that is disconnected. It is located on top of the snorkel just underneath the windscreen. It should say Denso on it. If that isn't it than it is your pair valve plug which means you probably have the pair mod and that plug isn't needed anymore. Hope this helps!
navymills is offline
View navymills's Profile View navymills's Gallery Find More Posts by navymills
Old 04-11-2007, 8:29 AM
Red Rider's Avatar
Bike(s): '01 CBR929
Try reading the thread...again.
Old 04-11-2007, 8:55 AM
2-Up SISSY
slickwill's Avatar
Bike(s): 2002 CBR 600F4i
Rep: slickwill has a spectacular aura aboutslickwill has a spectacular aura about (190)
And look at the date while you're at it
slickwill is offline
Old 04-11-2007, 5:43 PM
Bike(s): 04 RC51
Rep: txrc51fatboy is an unknown quantity at this point (9)
thanks in advance.
Jeff
this is the RC you tried to sell as the FASTEST IN THE US, correct?
txrc51fatboy is offline
View txrc51fatboy's Profile View txrc51fatboy's Gallery Find More Posts by txrc51fatboy
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 1:29 AM.
