Originally Posted by texasixes Is there anything I should look at getting done before the big Texas winter kicks in?
Also, should 50 degree weather make the bike such a hard starter, even w/ the choke pulled? |
50 degree weather is
relatively cold but shouldn't cause issues with your battery unless it sits for weeks or months without being run.
However, starting the bike, letting it warm up and driving around the block is not enough to get a good charge in the battery. If you're going to let it sit, get a Battery Tender and keep it hooked up.
