| Re: Slipper Clutches I have one in mine and it helps for the track. I should add though that I have a bad habit from dirt tracking of downshifting and dumping the clutch to start the back around. I can still chirp the back but it is hard to do. You can get the same effect by modulating your clutch.
I believe there is two types. One is a spider spring (my type) the other a ramp type. The spider spring is a wear item and the ramp may be better though I am unsure.
