Bike just shuts off
Old 03-11-2007, 3:26 PM
Bike(s): 2003 RC51
Rep: forceten is on a distinguished road (12)
Bike just shuts off
Went riding today, was a nice 50 degree day so i thought i would put put around town and get some miles in.
After about 1 hour of riding I was downshifting as I came to a light. Bike just shut off as I pulled the clutch in from 2nd to 1st. I didn't pop it back out cause I didn't even realize the engine shut down. At the light I restarted the bike after a try or two. Turning over sounded weak.
Bike started and I thought wierd but kept riding. 1/2 hour later same thing. Downshifting from like 3rd to 2nd and engine off. Again took me by surprise so i didn't pop the clutch. footed it off to the side of the road but this time bike turns over weak once or twice and then dead battery.
Had a tow truck come out and give me a jump. Bike started right up. Rode it home.
Dead battery? Or something else? Its sunday but I think I know who has a battery for RC's. Gonna replace it no matter what. But ya guys think something else is going on? What ever happened to a bad battery the engine would still power a car or bike until you stopped. Is it now a dead battery = engine off?
Hope its nothing more serious then that.
forceten is offline
View forceten's Profile View forceten's Gallery Find More Posts by forceten
Old 03-11-2007, 7:45 PM
Red Rider's Avatar
Bike(s): '01 CBR929
Re: Bike just shuts off
Most likely the battery needs replacing. If it happens again with a new one check the R/R.
Red Rider is offline
Old 03-11-2007, 7:53 PM
Hardcore 365 and 24
Bike(s): CBR1000RR, GL1800
Rep: A.F.T.C.T.T.G. is on a distinguished road (17)
More than likely the Batt. When you get it started again, disconnect Neg battery wire while bike is running and check voltage output across Pos/Neg battery wires to verify correct voltage to Batt.
A.F.T.C.T.T.G. is offline
View A.F.T.C.T.T.G.'s Profile View A.F.T.C.T.T.G.'s Gallery Visit A.F.T.C.T.T.G.'s homepage! Find More Posts by A.F.T.C.T.T.G. My Map Location
Old 03-11-2007, 8:36 PM
Bike(s): 2003 RC51
Everywhere is closed today after looking so I have to wait till monday or tuesday for a battery. I do have a power commander in and when I took the bike for inspection the guys said the idle was too high at 1800 and dropped it to like 1100 (the only change I can remember).
I guess after the battery is in place I can see what the voltage is doing from the charging system.
What numbers should be coming back across the wires to be healthy?
forceten is offline
Old 03-11-2007, 8:55 PM
Hardcore 365 and 24
I believe it's 12 to 14 VDC.
Old 03-11-2007, 11:09 PM
Doorbell broke, please sound fog horn!
leelover's Avatar
Bike(s): 06 FJR1300
Rep: leelover is just really niceleelover is just really niceleelover is just really niceleelover is just really nice (371)
If the charging system is not putting out enough voltage the ignition and fuel delivery systems will not work. If the batt is in bad enough shape (bad cell or shorted) it will not allow current to pass through correctly even if the charging system is functioning. If it is your original batt it is time for another.
I found the best deal at Batteries Plus, if you have them in your area.
After you install the new batt, check the voltage across the terminals. Start the bike and check again. The voltage should be more with it running, generally high 13 volt range. Rev engine slowly while watching the volts. It should go up slightly. If it goes down you need to have the charging system checked out by a tech.
leelover is offline
View leelover's Profile View leelover's Gallery Find More Posts by leelover
Old 03-11-2007, 11:47 PM
Bike(s): 2003 RC51
What rpms do you guys have your rc's idle at?
forceten is offline
Old 03-12-2007, 6:37 AM
Rigor's Avatar
Bike(s): 2003 Honda RC51, 1975 Suzuki GT550
Rep: Rigor is on a distinguished road (37)
1100-1300
Rigor is offline
View Rigor's Profile View Rigor's Gallery Find More Posts by Rigor
Old 03-12-2007, 8:38 PM
Bike(s): 2003 RC51
Crap, went out today for a ride, new battery and bike shut down three times.
Once slowing up to a light, clutch was pulled in going from 2nd to 1st.
Once while at a light clutch pulled in and in 1st waiting for a light to change.
Once in a parking lot. Pulled to a stop, kickstand down and in nuetral. was just sitting there for a sec and bike just shut right off.
Only good thing was since the battery was good the bike turned over each time and started right up.
But know I don't know what the hell is wrong. I'm pulling for either the bike idling too low (gonna up the idle tonight) or at the worst a bad kickstand switch.
Past that i guess I'm calling the honda dealer and seeing when I can drop it off to them.
Is it possible for a power comander to trip off a bike? I could try disconnecting that also to see if there is any change.
forceten is offline
Old 03-12-2007, 9:26 PM
Wish I had a fuel gauge
Bike(s): 1998 CBR 600F3
Rep: slorider18 is on a distinguished road (48)
check the voltage regulator. If the battery is charged the bike will run off of the batteries charge till it is too low power anything. if the voltage regulater is bad than the battery can't recharge = dead bike. I had the same thing just happen to my f3. New voltage rugulator and i am back on the road. Follow this link to get a charging system trouble shooting chart. it was really helpful to me. Motorcycle Electrical Parts (ElectroSport Industries)
slorider18 is offline
View slorider18's Profile View slorider18's Gallery Visit slorider18's homepage! Find More Posts by slorider18 My Map Location
Old 03-12-2007, 9:41 PM
Bike(s): 2003 RC51
Looks like the voltage regulator is in the tail on my RC, I can see it from the trunk. Its also hot as hell to the touch.
forceten is offline
Old 03-12-2007, 11:12 PM
Yup, if they get to hot they fry. i fried mine when my bike over heated. Simple fix and you will be draggin' your knee again in no time.
Old 03-13-2007, 7:57 PM
Bike(s): 2003 RC51
Any online part place have a rectifier cheaper then my local dealer ($180 the bastards)
forceten is offline
Old 03-13-2007, 7:59 PM
mine cost the same from the dealer. i hate those guys. anyway, i found several on ebay new for around $100.00. i purchased a used oem rr for $30.00. good luck.
Old 03-13-2007, 8:18 PM
  #15
Bike(s): 2003 RC51
yeah I looked on ebay and at the moment they only show 00's and 01's, I can't seem to find and for sp2's anywhere online.
Damn dealer prices grrrrrrrrrr
forceten is offline
Old 03-13-2007, 8:53 PM
  #16
leelover's Avatar
Bike(s): 06 FJR1300
Check out Honda Kawasaki Suzuki Yamaha Motorcycle Parts Accessories Repair Manuals and Ron Ayers' web site.
leelover is offline
Old 03-13-2007, 9:47 PM
  #17
Bike(s): 2003 RC51
$115! Much better at mrcycles! Thanks much!
forceten is offline
Old 03-13-2007, 10:00 PM
  #18
leelover's Avatar
Bike(s): 06 FJR1300
no prob
They have a really good parts micro fiche system, too.
leelover is offline
Old 03-13-2007, 10:17 PM
  #19
Bike(s): Mostly broken Track bikes
Rep: SP2Pilot is an unknown quantity at this point (9)
Ok a couple things
If the battery cables are disconected the bike will die instantly, so the person telling you to check voltage by disconecting the cables while the bike is running is doing you no favors.
Second. How do you know you have a charging problem?
If the battery is up after you ride for an hour it ain't a problem so the regulator and rectifier are not bad
third You need to go ahead and get someone that knows what the heck they are doing to do a amp draw load test to see if the charging system is at spec. You need to pull 13.5 volts at 1500 RPM Min.
SP2Pilot is offline
View SP2Pilot's Profile View SP2Pilot's Gallery Find More Posts by SP2Pilot
Old 03-13-2007, 10:57 PM
  #20
if a charging system is working properly the bike will run after the battery is disconected. all the battery is for is to get the bike started. after that it should be able to opperate without the battery. if this is not the case then there is a problem with the charging system.
Old 03-14-2007, 10:14 AM
  #21
No the RC 51 will not run with the battery disconnected. I will bet you the pink slip on my bike.
This is not a 1977 Chevy pick up
SP2Pilot is offline
Old 03-14-2007, 3:02 PM
  #22
you guys with all your fuel injection and power comanders. i geuss maybe it's time for me to get updated....
(yelling at my wife) "honey, SP2Pilot says i need to get a new bike, i think he's right."
We'll see if that works....
Old 03-14-2007, 3:11 PM
  #23
Bike(s): 2003 RC51
Why do people say pink slip anyway? My title is white in color
forceten is offline
Old 03-14-2007, 4:17 PM
  #24
Rigor's Avatar
The same reason they say, "Better then sliced bread". Apparently one day, there was nothing better then that.....
Rigor is offline
Old 03-14-2007, 9:45 PM
  #25
Bike(s): 2003 RC51
BTW guys, I upped my idle today (was a fantastic day out, almost 70 degrees here) and rode for about 2 hours after work.
No shut downs at all. That leads me to think the idle was way too low. I had it first set back to 1800 but then after the bike warmed up a bit i set it down to about 1500 and so far so good.
I will give it a few more days of riding to see if that was the real problem or not.
forceten is offline
Old 06-28-2007, 6:31 PM
  #26
Bike(s): sp2
Rep: wtme600 is on a distinguished road (10)
check batt. leads are tight even a bit lose and when the bike starts to flex it can do strange things
wtme600 is offline
View wtme600's Profile View wtme600's Gallery Find More Posts by wtme600
Old 06-28-2007, 6:47 PM
  #27
Bike(s): 2003 RC51
That was months ago, problem happened to be the idle was too low on the bike. Upping the idle is what really solved the problem
Was idling like at 1k
forceten is offline
Old 06-28-2007, 7:59 PM
  #28
I'm groovin b**ches
jhonda41's Avatar
Bike(s): 95 VFR
Rep: jhonda41 will become famous soon enoughjhonda41 will become famous soon enough (100)
no... the problem is you're letting your bike idle TOO much.
-jh
- Track whores get paid for it, track sluts do it for free...
- Cars lean the wrong way in turns.
jhonda41 is offline
View jhonda41's Profile View jhonda41's Gallery Find More Posts by jhonda41 My Map Location
Old 06-28-2007, 8:17 PM
  #29
Bike(s): 2003 RC51
would shut off as I downshifted to a light
forceten is offline
