Here's my new (ish, 1600 miles on the clock) 2006 model. Only added an HRC tank pad for now, not sure if I will do anything else cosmetic or even exhaust wise (UK trackdays are quite strict on noise limits)
this is the latest pic of mine...doing a little winter mod..
1) Hid conversion from xenon depot. 6500k
2) 15/41 520 conversion from dk
3) Sent gauges to have leds changed......should be here this week
I will post pics when finished.
i received the cluster back today and though i would post a pic..they were done by bluegauges.com. The turn around was quick and they work is very good!!!!!
Iv seen them and want that done to mine.. but can't find a place that does it in the UK. I think 70 to change the LEDs is extortionate... but still I would grudgingly pay it... but I sure won't pay 70 plus all the extra to get it shipped to the USA and then pay to get it shipped back ontop of that... I would be paying in excess of 200!! To change 3 LED's? No thanx...
so take 70 for the work, then 38 from Italy to USA and then 38 from USA back to Italy... 146.
So 146 to change 3 led's? nah...
Don't get me wrong... if a guy did it locally yeh I would pay the 70!! But to pay more for the postage than the actual work is NOT something I would be willing to do.
My 2004 RC51 it weighs around 435lbs with a full tank ready to ride. I will have my underhung brake kit on this week and I will be adding a carbon air box and carbon snorkel along with ceramic rotors. Below is a list of what I hve done so far. http://www.fireblades.org/gallery/fi...9/100_0637.jpg
2004 Honda RC51 Nicky Hayden Edition
Brakes Galfer super bike front lines, Galfer rear brake and clutch lines, HRC race pads, Brembo full floating rotors, Galfer rear wave rotor, Brembo 19x16 billet radial brake master cylinder with shorty lever, Brembo Under hung rear brake kit. Suspension Ohlins 3 way adjustable racing rear shock & Kyle rear shock linkage, Pilot Power 2CT, BST carbon fiber wheels, Scott’s steering damper, Ohlins RT forks, Custom billet aluminum adjustable kickstand. Engine Soft rev mod, Ceramic headers, Yuasa YTZ7s battery, Moriwaki carbon fiber radiator vents, Carbon fiber radiator ducts, 2007 CBR coil kit Hyper plates aluminum clutch plates Yoyodyne ball bearing slipper clutch PCIII USB with Kyle map & Accelerator pump mod SATO Ti low mounts with Banzai carbon fiber mufflers Derestricted, pair mod, flapper mod, Redline water wetter, DID ERV3 520 Gold chain, Stealth 41 rear & AFAM 15 front. Cosmetics Carbon front fender G-Craft mini reservoir Cut down sub frame & re-wired tail section SATO TI exhaust hangers, Eyebrow blinker mod HID 6000K headlights, Flush mount screw kit Carbon fender hugger, Carbon tank guard, Dark smoked wind screen, Nicky mod, CRG hindsight mirror, clock, carbon chin fairing Hot bodies custom under tail with custom LED taillights, Watsen LED flush mount signals, HRC reservoir covers, TWM carbon fiber keyless gas cap, bar sliders, frame sliders, swingarm sliders, HRC Superbike replica fiberglass tail. Controls
SATO gold rear sets with GP shift kit, Brembo 16x18 Billet radial clutch master cylinder with shorty lever, Brembo 19x18 Billet radial master cylinder with shorty lever, HRC 1/6th throttle kit, and Safety wired bike.
Ok, all repaired and good to go. After an August lowside which required a new right side and a new exhaust (full hindle with titanium cans) I am once again good!
Here is mine. I had to sell her though (fargin economy!). I wanted to ride her in retirement
Ohlins RT Forks
Ohlins 3 Way Shock
Moriwaki Dogbone
Marchesini Forged Aluminum Wheels, clearcoat baked on them to protect
Brembo floating rotors
Brembo master cylinders, brake and clutch
Scotts Steering Damper
Goodrich S/S lines (Both brakes and clutch)
Moriwaki C/F Front Fender
Harris C/F Hugger
Sato Clip Ons
Sato Rearsets
Sato Banzai C/F Slips
520 15/41 conversion
Ahlman's speedo correction box
PCIII w/DK Banzai map
Ladycraft Rear resevoir
Corbin seat for my twisty rides
Moriwaki radiator ducts
Harris Frame Sliders
Billet Aluminum Upper Triple Clamp
Billet fuel cap
All free mods done (Pair, Soft Rev, etc)
Nicky Mod
All bodywork clearcoated for protection
That's all I remember off the top of my head, sure there is more.
A questiona bout the Moriwaki radiator ducts... can they be painted? I have looked around and can only find them in carbon fibre... personally if I got them I would want them white to match my bikes fairing... but if they are only available in carbon fibre then I would have to paint them (no big deal) but is there a reason why they arent available in plastic? Too hot? If so then wouldnt the heat effect the paint if I were to get them painted?
I want to know if there is any hard evidence that they work? I mean I read once that one "MOD" was to reverse one of the radiator fans....ummm if you reverse a radiator fans direction then it will be blowing against the flow of the air.....what is the point of that?
