Originally Posted by legendnum2 Hey y'all, ive tried to read up on this as much as possible, and still have yet to get my battery tested. I just picked up a 03' rc51 with 800 miles on er, I keep getting a low speed hesitation/ lurch when releasing the clutch aorund 1500 rpms, if i keep the rpms past 3 it wont happen, but coming out of a light with a car in front of me that can be rather difficult.
I also rode my friends SP1 and his had no similiar problem
I have tried fuel injector cleaner/ tightened battery terminals/ changes plugs/ and went through 2 tanks of gas. |
The RC51 is geared high from the factory. the 16/40 gearing on it makes for a great top speed, but crappy when pulling out. I'll have to assume your friend's SP1 is stock geared as well.
Another part of the problem, is the clutch is either in, or out, with very little freeplay or feedback when compared to other bikes. Add the clutch function plus the high gearing and it's a bitch sometimes....especially on an incline.
The BIGGEST issue, is If you're releasing the clutch at 1500 rpms, that's too low. My bike idles at 1500.... facory recommends 1200-1400.....
Feathering the throttle at clutch contact, then accelerating works the easiest for me.
Do yourself a favor and change your gearing to the desirable 15/41 set up, (your old chain is new enough and will fit over the new gears) and you'll fall in love with the bike, and notice a seat in the pants difference with acceleration, as well.
After that....let's see if I can get you to buy the rest of the stuff to make you love the bike even more.
