Originally Posted by RoooStEr I heard that the 190-55-17 actually has a taller contour than a 180-55-17 is this true? |
Well....lets do the math together.
190-55x17 rear tire:
190mm width (sidewall to sidewall, not just tread)
55% sidewall aspect
17" diameter.
55% 0f 190mm width is 104.5mm tall, from ground to rim.
180-55x17 rear tire:
180mm width
55% sidewall aspect
17" diameter.
55% of 180mm width is 99mm tall, from ground to rim.
The difference in ride height from a 190-55 to a 180-55 is 5.5mm, or a total of 11mm taller all together, from ground to top. Both tires add to the bike's ride height, and increase turn-in abilities. Their "crowned" tread also helps, vs the flatter profile of the stock 190-50 series tire.
This is a theoretical, Mathematical explanation. In reality, different tires, although marked with the same size, can vary in height, based on that manufacture's specifications and design. Dunlops are enherantly taller then most tires.
