reason for getting rid of the flapper valve?
07-29-2007, 3:24 AM
Bike(s): 2006 honda rc-51 2003 kawasaki ninja 250 Posts: 11
| reason for getting rid of the flapper valve? I am going to put a pc on my bike with pipes and am haveing a licensed dyno tech guy program it, but I here people reference getting rid of the flapper valve, why would this be? |
07-29-2007, 7:12 PM
Bike(s): 2006 CBR1000RR Posts: 527
Rep:  (15) Rep Power: 2
| Re: reason for getting rid of the flapper valve? More Powa! |
07-29-2007, 7:21 PM
Bike(s): "04 CRF250X '05 Repsol Posts: 93
Rep:  (18) Rep Power: 2
| Re: reason for getting rid of the flapper valve? When you're below 3k the flap is closed restricting air intake. When you plug the hose and keep it open you'll notice the difference immediately, some disassemble the whole thing and get an air intake. The rear flap in the exhaust will go when you put the pipe on, just disco the cables from the servo motor on the left side of the bike rigth below the tank. Then you get the 15tooth front sprocket and you'll be set.
07-29-2007, 7:24 PM
| Re: reason for getting rid of the flapper valve? Sounds better too. |
07-29-2007, 8:07 PM
#5 | | Feel The Power Between My Legs
Bike(s): CBR954RR, Hornet CB900F-5, VFR800FI + More Posts: 2,486
Rep:  (45) Rep Power: 4
| Re: reason for getting rid of the flapper valve? Hi sorry to bother you but im still abit weary about what it does. COuld you explain in more detail? please...?
Also, if you have time could you write an easy step by step guide of how to do it?
Im in the process,but am stuck on what to do. What will happen after i block it, will it run better/worse - richer etc?
Thanks |
07-29-2007, 8:13 PM
| Re: reason for getting rid of the flapper valve? I can't say what it does to the A/F ratio but the rumor is;
Honda claimed they out it on to add low end power'
Speculation on that was they really did it for sound/emission reasons.
General Consensus is that the butt dyno reads more power all around without it.
There is even some dyno charts around showing power added after removing/disabling it. If you need the step by step on how to do it, just use the search function. If you don't want to remove it all together it is as simple as pulling the hose off the actuator and plugging the hose with a bolt or something. |
07-29-2007, 11:55 PM
Bike(s): Honda RC51 Posts: 14
| Re: reason for getting rid of the flapper valve? This should help you. LINK |
07-29-2007, 11:58 PM
| Re: reason for getting rid of the flapper valve? Quote:
Originally Posted by JetFxr This should help you. LINK | Thanks. I'd a posted it for him but my computer crashed and the wife's laptop here doesn't have it as a favorite on it. |
07-30-2007, 5:07 AM
#9 | | Feel The Power Between My Legs
| Re: reason for getting rid of the flapper valve? Hi,
Thanks everyone.
One question lingers, if i were to take my bike back to the MOT station, would it be pulled up on it? Or wouldnt they even know to someone who is just like servicing the bike?
I will have to change my Micron can to my standard silver one as mine is not road legal, but thats life.
Anyhoos, going to jump on the blade now.
Take care |
07-30-2007, 8:17 AM
Bike(s): 2001 CBR929RE1 Age: 31 Posts: 1,155
Rep:  (63) Rep Power: 8
Originally Posted by Twincam Hi,
Thanks everyone.
Take care | me don't understanding question.
what do you mean by pulled up? ... you mean computer detecting the flapper mod, or if only a service tech would be keen enough to notice the change?? |
07-30-2007, 10:45 AM
| Re: reason for getting rid of the flapper valve? If you only put a bolt or something in the hose then it would only take you a minute to take the bolt out and re-attach the flapper valve anyway. I don't know what anyone would notice or care about it though. |
07-30-2007, 1:43 PM
Join Date: 05-28-2007 Location: SW Ohio "Buckeye Country"
Bike(s): '03, CBR954RR; Titanium & '04 CBR600RR; Blue Age: 39 Posts: 513
Rep:  (32) Rep Power: 2
Originally Posted by HCCAFan I can't say what it does to the A/F ratio but the rumor is;Honda claimed they out it on to add low end power' Speculation on that was they really did it for sound/emission reasons. General consensus is that the butt dyno reads more power all around without it.
There is even some dyno charts around showing power added after removing/disabling it. If you need the step by step on how to do it, just use the search function. If you don't want to remove it all together it is as simple as pulling the hose off the actuator and plugging the hose with a bolt or something. | It seems strange to me that one can add power by restricting air flow. I could possibly see benefit to this device as it could give Honda the ability to "smooth" the power delivery some (by actually reducing power "spikes" in certain areas), but I'm not sure I would believe it adds power. This may have already been debated and hashed out somewhere, I didn't spend any time searching for it. |
07-30-2007, 1:53 PM
#13 |
Originally Posted by Phadreus It seems strange to me that one can add power by restricting air flow. I could possibly see benefit to this device as it could give Honda the ability to "smooth" the power delivery some (by actually reducing power "spikes" in certain areas), but I'm not sure I would believe it adds power. This may have already been debated and hashed out somewhere, I didn't spend any time searching for it. | Hey man, I didn't make it up! I know for a fact on a turbo car that a boost leak can give you more torque and less HP. Maybe by restricting air on a N/A bike they figured out it does the same thing. Just like you, most people didn't buy the idea and that's the reason so many disable it. |
07-30-2007, 2:13 PM
#14 |
Originally Posted by HCCAFan Hey man, I didn't make it up! I know for a fact on a turbo car that a boost leak can give you more torque and less HP. Maybe by restricting air on a N/A bike they figured out it does the same thing. Just like you, most people didn't buy the idea and that's the reason so many disable it. | Easy...I'm not suggesting your making up anything, I'm suggesting the concept doesn't make sense to me, that's all. You did just hit on something that might be a clue; by restricting air volume with the flapper, you may increase air velocity which most definitely can have an impact on Torque. It would be most apparent at lower RPM's, which would also explain why it's closed at lower RPM's. Hmmm.... Cheers my friend! |
