Hi guys,
I'm back from a 5 day trip around Macedonia (former republic of Yugoslavia) and had to tow my 2001 SP1 for last 400 kilometers... The problem happened on the last day of the trip, when I noticed lots of white smoke coming out of my Leo Vinci pipes when I fired it up...
The bike hasn't been overheated (I always monitor the engine temperature rather carefully and it is always at around 76-85 degrees Centigrade) and it wasn't abused that day at all (I was in a motorcycle rally with more than 400 bikers, doing 80-90 km/h most of day). I have always driven the bike at around 2k rpm until it got to the working temperature, but I did ride it hard after it is completely warmed up (the bike is built for that, right
During that day, I've started the engine and I noticed lots of white smoke coming out (not blue or dark smoke), but the engine was running just fine. I've stopped it in order to check the oil level - level was at the max and the color was brownish, slightly transparent (I'm using Bardahl XTC 20w60 since the bike was brand new, without any problems). I fired it up and continued driving slowly to check what's happening, since my first thought was that it was something bad with the fuel...
After a mile of riding, the smoke disappeared and I continued riding it for around 100 kilometers, without any noticeable changes in engines behavior. However, when I was about to stop, the white smoke came right back pouring from the exhaust... At that point the engine temp started to rise and I had to pour more water into the cooling system, which proved that it is definitely wasting water... After that I've called my friends with a trailer to tow the bike back to Belgrade.
The good thing is that the bike still works just fine (which confuses me a little) and the oil doesn't have any water inside (no bubbles or milky layers). I'm guessing that its a blown head gasket or (worse case scenario) one of the heads have a crack somewhere inside...
Do you guys have any thoughts about what may have happened and/or had some similar problems on your sp1/sp2/rc51 bikes?
BTW, I forgot to mention earlier that the bike has around 48k kilometers and didn't have any engine problems so far.
Thanks,
Ivan
