Originally Posted by solaidrider667 I have a 2002 SP2 with 6500 miles and all stock and at idle I can hear the valves/lifter tapping----not super loud but definately there. I also have a 2000 SP1 with 12000 miles Mig High Mounts-Power Comander. I can hardly hear any "tapping" The 02 runs fine---also oil change and no difference in volume. Is it possible that due to the stock very quiet mufflers I am hearing normal engine noise. I think valve adj is at 16k? Thanks |
this is what i know and its not much...also hope its a help.
vavles will get tight on some bikes. when there is some play between the cam and the vavle you'll get that tick. quiet vavles maybe tight valves, maybe . tight valves are worse than slightly loose valves. 16k is the vavle adjustment spec. ive had a bike, a sv, that got the valves adjusted got it back and it ticked dealer said that it was set loose but it was still within spec and would quiet down over time, it did.
so maybe the 2000 is getting tight and the 02 is loose, but within spec
how do they run? tight valves will run like crap
