HELP!!
Old 02-28-2008, 12:15 PM
Chum's Avatar
Bike(s): 2005 RC51
Rep: Chum is on a distinguished road (12)
HELP!!
Ok, so I'm rebuilding a 2001 RC51 that was layed down. Its been sitting up for about 6 or 7 months, and I cant get it started! Being that I'm not firmiliar with motorcycle repair, is there anything obvious that I might be missing? The motor turns over it just wont fire up. Is there any fuses I should check, or something that needs to be reset? To eliminate a few things, it is in neutral and the kill switch is off. Thanks for all your help!
Chum
Chum is offline
View Chum's Profile View Chum's Gallery Find More Posts by Chum
Old 02-28-2008, 12:43 PM
Team Visa Racing
nedro's Avatar
Rep: nedro is just really nicenedro is just really nicenedro is just really nicenedro is just really nicenedro is just really nice (443)
Re: HELP!!
Buy a factory Manual for your bike.
www.helminc.com
Best $100.00 you'll ever spend!
Ride Red
nedro is offline
Old 02-28-2008, 1:51 PM
CBR400RR's Avatar
Bike(s): 2004 Honda RC51
Rep: CBR400RR is on a distinguished road (23)
Re: HELP!!
www.helminc.com
I have it on PDF and there are a few places you can get it for free.
WWW.SCOTTSMS.COM
CBR400RR is offline
View CBR400RR's Profile View CBR400RR's Gallery Visit CBR400RR's homepage! Find More Posts by CBR400RR
Old 02-28-2008, 1:52 PM
CBR400RR's Avatar
Re: HELP!!
Chum
The fuse for the headlights also controles the fuel pump and if your Tip over sensor is unhooked the bike won't start either.
WWW.SCOTTSMS.COM
CBR400RR is offline
Old 02-28-2008, 1:56 PM
Chum's Avatar
Bike(s): 2005 RC51
Re: HELP!!
Where is this tip over sensor? I found what appears to be the fuse box. It houses about 6 fuses. None of them look bad but I might just replace them anyway to see if that helps.
Chum is offline
Old 02-28-2008, 2:00 PM
CBR400RR's Avatar
Re: HELP!!
Always test fuses with a test light as they can look good and still be bad. Turn on the key and test each side of each fuse. The TIP sensor is under the tail section above the swingarm. It's a little black box with a round top and flat bottom and sides and has an arrow pointing up.
WWW.SCOTTSMS.COM
CBR400RR is offline
Old 02-28-2008, 2:04 PM
Team Visa Racing
nedro's Avatar
Re: HELP!!
www.helminc.com
I'll make you a deal.
I won't tell anyone if they can get a better price on something you sell, if you don't tell people to steel from another business. O.K.?
Ride Red
nedro is offline
Old 02-29-2008, 1:49 AM
CBR400RR's Avatar
Re: HELP!!
I'm not the one that is hosting it online for free and $100.00 is way too much to pay for a manual, I'm just trying to help the guy out not rip him off for $100.00
WWW.SCOTTSMS.COM
CBR400RR is offline
Old 02-29-2008, 3:23 AM
Bike(s): 2003 RC51
Rep: chickens_daddy is on a distinguished road (10)
Re: HELP!!
I had the same problem with my rc51 when I laid it down. If it's a right side slide like mine was, make sure you didn't lose any fluids. I lost some out of the clutch cover. I changed the gasket, got a new cover, did an oil change and she fired right up. The manual shows you how to check your tilt sensor; basically you unscrew it from it's mount, tilt it greater than 60 degrees, and try to start your bike. If she doesn't turn when the sensor's tilted but does when the sensor's in upright/neutral, you're sensor's working. Good luck on getting her running!
By the way, enough on-line research will land you a manual for whatever you want to pay for it, anywhere from free to $100. It just depends on how diligently you search for what you're looking for. I found one on Ebay for less than $50, but you could find one for free if you search hard enough. You can't steal something that's being posted for free. No offense intended, just stating the obvious. Anyway, hope you get your bike running, Chum. Again, good luck to you!
chickens_daddy is offline
View chickens_daddy's Profile View chickens_daddy's Gallery Find More Posts by chickens_daddy
Old 02-29-2008, 12:54 PM
Bike(s): 95 F3, 05 1000RR, 00 Busa ......and a few more.
Rep: oldnslow is on a distinguished road (11)
Re: HELP!!
The tip over sensor would be my first guess.
oldnslow is offline
View oldnslow's Profile View oldnslow's Gallery Find More Posts by oldnslow
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 6:43 AM.
