| Re: running lights....not running
Do the blinkers appear to blink brighter or dimmer than they did before? How about faster or slower? If the shop had to undo the wiring, they may have reversed your running light wire with the ground - easy to do if you have aftermarket blinkers that don't have the same color wires as the factory harness.
Otherwise a few minutes with a voltmeter should get you somewhere. And as CBR929RE said, you might just have burnt out both filaments. Believable on some of the cheap aftermarket blinkers I've had experience with.
