Front brake question...
Old 04-01-2008, 4:28 PM
Bike(s): 2000 RC51
Rep: mossdahaus is on a distinguished road (10)
So I went out for a ride today and when I got back, I was rolling the bike with the engine off and heard what I thought to be a dragging front brake. Is this possible with the floating rotors and even more so, what causes it? I could just be hearing things but I wanted to make sure...
mossdahaus is offline
View mossdahaus's Profile View mossdahaus's Gallery Find More Posts by mossdahaus
Old 04-01-2008, 4:49 PM
Bike(s): 2006 blue and yellow 1krr
Rep: ldavis is on a distinguished road (20)
Re: Front brake question...
it's typical. i can't explain it technically but it has to do with the pressure from the pistons.. they aren't forced back out so you'll get a rubbing sound. i'm sure someone else will give you a better description.
ldavis is offline
View ldavis's Profile View ldavis's Gallery Find More Posts by ldavis My Map Location
Old 04-01-2008, 5:25 PM
rokitt51's Avatar
Rep: rokitt51 is on a distinguished road (30)
Sometimes it happens and at other times it dont (with my bikes). I dont think that there is anything wrong though.
rokitt51 is offline
Old 04-02-2008, 2:42 AM
Bike(s): 2005 rc51
Rep: imhambone is on a distinguished road (10)
it depends on how warm your brakes are bro. usually when they heat up they tend to expand a little and rub. its definently nothing to worry about
imhambone is offline
View imhambone's Profile View imhambone's Gallery Find More Posts by imhambone
Old 04-02-2008, 4:52 AM
Bike(s): 06 CBR 1000rr
Rep: Jhellstr is on a distinguished road (10)
Disk brakes to not have return spings like drum brake assemblies. When the brakes are applied it simply squeezes the brake pads against the rotors and when the pressure is released they naturally drag slightly. Not a problem at all.
Jhellstr is offline
View Jhellstr's Profile View Jhellstr's Gallery Find More Posts by Jhellstr
Old 04-02-2008, 5:10 AM
-Z-
Gearhead/Sportbike Nut
-Z-'s Avatar
Bike(s): 1999 VFR800, 2002 954
Rep: -Z- will become famous soon enough (93)
Send a message via AIM to -Z-
All of my bikes make that little bit of noise whenever the front wheel is rolling. Some more than others, but still they all have it.
-Z- is offline
View -Z-'s Profile View -Z-'s Gallery Find More Posts by -Z- My Map Location
Old 04-02-2008, 6:32 AM
Bike(s): VTR1000SP2
Rep: stasik-a4 is on a distinguished road (10)
Caliper have rubber seals that act as springs like in grums... pistons rely on ruber seals to pull the piston back the rubber seals also there to stop the brake fluid to leak. You got to work out whether the sound is coming through out the whole rotation of the tyre ie 360 degries which would mean that discs are hot and expanded but if the noise is there for only a 1/4 or a 1/3 of full rotation then i would say that your discs might be slightly warped... Im no expert with the bikes but im an ex car mechanic and the bace principal is the same...
stasik-a4 is offline
View stasik-a4's Profile View stasik-a4's Gallery Find More Posts by stasik-a4
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 8:43 AM.
