Knocking noise when taking off
Old 05-07-2008, 11:44 PM
Bike(s): 02 Honda RC51
Rep: rc514789 is on a distinguished road (10)
Whenever I'm sitting at a red light and go to take off there is a relatively loud knocking sound coming from the bike somewhere!!! I here it and it gets louder untill i get up to speed then I here it in second a lil. I can't figure out what it is. My bike is an 02 RC51 with almost 16,000 miles, could it be the valves? or the clutch? Please help
rc514789 is offline
View rc514789's Profile View rc514789's Gallery Find More Posts by rc514789
Old 05-08-2008, 11:48 PM
rokitt51's Avatar
Re: Knocking noise when taking off
Could be the valves and the clutch too. But check the cheaper routes first. Check the chain and the sprockets, they could be causing the knocks that you hear. My RC was valve checked at over 16,000 and was all good, and i do alotta ridin.
rokitt51 is offline
Old 05-09-2008, 9:03 AM
What do I need to check on them?
rc514789 is offline
Old 05-09-2008, 10:09 AM
Bike(s): 2002 Honda RC51 SP2
Rep: Beattie_Yo is on a distinguished road (10)
a service manual will tell you everything you need to know do do the inspection yourself. i believe all you need is a a few metric tools and some feeler gauges to measure clearances with. most of the labour involves removing the bodywork and tanks to gain access to the front/rear cyl heads
a looser chain can also cause a bit of rattle which can cause a hiccup in 1st-2nd gear transitions. check tension of and lube chain as often as you can remember...2cents
Beattie_Yo is offline
View Beattie_Yo's Profile View Beattie_Yo's Gallery Find More Posts by Beattie_Yo
Old 05-09-2008, 8:37 PM
So I was ridin home from work tonight and was listening to it. It does it in every gear, and only while giving it throttle, and it comes from the front of the motor it sounds like. But its getting worse, when it first started happening it was just like one knock and now it just knocks and knocks as long as i'm on the throttle partially
rc514789 is offline
Old 06-12-2008, 4:44 AM
Bike(s): RC51, KTM640Motard, RMX250
Rep: playwme is on a distinguished road (10)
Is your chain loose?
playwme is offline
View playwme's Profile View playwme's Gallery Find More Posts by playwme
Old 06-12-2008, 8:22 PM
Bike(s): rc 51 rat rod
Rep: breimers is on a distinguished road (10)
First lube your chain. I Don't suspect your chain because usually under load a chain will not make any noises unless the roller pins are completely wornout. Lubing with a thick chain lube will help eliminate the chain noise. I would suggest looking at your front sprocket. The loose or worn out chain may be chattering against a worn out sprocket.
I would not suggest you check the valves unless you are an experienced mechanic. they are a pain in the butt. The valves are not adjustable as most older Hondas. They have shims under push caps, will require you to remove the cams to replace the shims and the recheck the clearance. Good luck hope my advice helps.
breimers is offline
View breimers's Profile View breimers's Gallery Find More Posts by breimers
Old 06-19-2008, 2:11 PM
Bike(s): Kawasaki H2, RC51
Rep: jzanutto is on a distinguished road (11)
if you or the previous owner have been doing burnouts, wheelies all the time, hard acceleration then the rear sprocket teeth may be letting that chain slip.
Look at the teeth on the rear sprocket. Go down to a bike shop and look at a new one on a rack if you need a good comparison for tooth height. My daughter's ZX7 was doing this until she finally told me about it and sure enough there were almost no teeth left on that rear sprocket
people tend to put aluminum rear sprockets on in an effort to save weight. they wear out fast
jzanutto is online now
View jzanutto's Profile View jzanutto's Gallery Find More Posts by jzanutto
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 1:51 AM.
