Honda Motorcycles
Navigation » Honda Motorcycles - FireBlades.org > Honda Motorcycle Models > Honda RC51 » Lower temp fan switch
Honda RC51 Discussion of the Honda RC51, Honda SP1, and Honda SP2 Motorcycles.
Old 04-20-2010, 7:40 PM   #91
jrivas's Avatar
Reputation Power: 23
jrivas has a brilliant futurejrivas has a brilliant futurejrivas has a brilliant futurejrivas has a brilliant futurejrivas has a brilliant futurejrivas has a brilliant futurejrivas has a brilliant futurejrivas has a brilliant futurejrivas has a brilliant futurejrivas has a brilliant futurejrivas has a brilliant future
Re: Lower temp fan switch
well put there zero, its actually pretty easy that way jarhead, you cant go wrong with the switch, hell i have mine to where even if the gauge is showing the mileage instead of the temp, my switch has a light to it, if the light is off, that means im over 218 and the fans are doing work son, if the light is on, im below 218. if i see it reachin that 218 and im in traffic, switch that puppy on and no worries............the lady will have no problems i hope
"So they've got us surrounded, good! Those b*****ds won't get away this time!"
CHESTY PULLER, USMC
jrivas is offline   Reply With Quote
Go Back   Honda Motorcycles - FireBlades.org > Honda Motorcycle Models > Honda RC51
Visitors found this page by searching for:
http://www.fireblades.org/forums/honda-rc51/64598-lower-temp-fan-switch.html
sp-1 fan switch
rc51 fan switch
honda motorcycle fan switch
fan switdh for honda motorcdycle
motorcycle fan control
190 degree thermal switch
pictures of wiring a manual fan switch on a motorcycle
how to 12 volt relay and toggle radiator temperature switch
does a motorcycle thermostat also control the fan
motorcycle fan control switch
how to power a thermal fan switch on a motorcycle
motorcycle manual fan control switch
motorcycle manual fan controller
RC51 relay SW524
motorcycle manual fan switch
190 DEGREE FAN SWITCH
HOW TO LOWER MOTORCYCLE TEMP
honda sp1 thermal switch
honda motorcycle thermostatic switch
motorcycle fan manual switch
how to hook up a togle switch on a motorcycle fan
temperature switches m16
hot to lower motorcycle temp
You may not post new threads
You may not post replies
[IMG] code is Off
Manual cooling fan switch 2001 CBR929RR Honda FireBlade 10 08-23-2007 5:48 AM
1998 cbr900rr; thermo fan; temp thinlyspread Honda FireBlade 6 12-11-2006 3:10 AM
929 Fan Switch Temp Setting? Baketech Honda FireBlade 3 03-09-2006 7:41 PM
Fan temp??? MrX954 Honda FireBlade 14 03-25-2005 6:09 PM
Higher octane equals lower temp 1pcbr Honda FireBlade 12 12-10-2004 11:14 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98
