| Re: Need help setting up suspension on 02 RC I was in your situation. I could not generate any sag with the stock shock...none. I had that big fat yellow spring backed off to zero and yet the rear would not drop a mm when I got on.
I bought a Penske 8987 Triple Clicker and OMG what a difference. On top of lowering the bike over an inch, the handling is now out of this world good. Without any hyperbole, I shaved 3 seconds of my lap times of 1:12. I can now drag a knee with high rear sets, and I even had the rear step out as she settled in on the swing arm sliders, at lean angles I'd only read about!
The RC51 is so awesome and predictable, I was able to pick it up off my knee and continue riding with little more than a load of crap in my leathers. I love my RC51 now that I have a proper suspension.
More to come...at our weight, the Race Tech fork spring replacement with a set of .95's will blow you away too. It give even more feel to and feedback from the front.
Don't forget to suck those forks up in the triple clamps if you lower your rear with a shock replacement.
Bottom line, you will NEVER get that stock shock to do what you need. Spend the $1000 to $1200 and get a better shock.
Penske, Elka, Ohlins, Hyperpro etc. all make great shocks matched to the rider. |
