Problem with turn signals
Old 07-26-2008, 11:05 PM
Bike(s): '00 RC51 & '05 VTR100F
Rep: ugt33 is on a distinguished road (10)
Apologies in advance for the essay below - but any suggestions would be gratefully received!
Removed the home-made fibreglass undertail from my RC51 ready to install the shiny new black hotbodies version..... that's when i realised what a mess the bikes electrics were - cut wires everywhere, ecu flapping in the breeze, and the real beauty - wires running from the back of the bike to the front of the bike, twitched onto various parts of the original loom.
SO.... after about four hours of tracing and rewiring, i've discovered that the front-to-back wires are for the rear turn signals. Whoever installed the old undertail has cut the +ve wires to the turn signals that emerge from the main wiring loom, and replaced them with a feed from the +ve wire on the front signals (hence the front to back wires running separate from everything else).
I have installed the new undertail and lights, and set the wiring back to how it should be. Two problems I now have - using the orignal +ve wire makes the right turn signal very faint. The left is fine, but the right is almost invisible. (it's not the leds - if I swap the left and right wires, the leds are fine). Does anyone know why this is, and if it's a fault or just what happens when you fit leds? If i go back to the front/back wiring the last guy rigged up, it works perfectly (apart from the next issue below).
Second problem - i've also installed a flasher rate adjuster to make the led turn signals work properly, but if I connect it all four (front and rear) turn signals flash at once regardless of which turn signal is engaged. Again, is there something I'm missing, or is this just a result of the front-back rewiring thing?
Thanks in advance for reading this epic...
ugt33 is offline
View ugt33's Profile View ugt33's Gallery Find More Posts by ugt33
Old 07-27-2008, 1:52 AM
Bike(s): Kawasaki H2, RC51
Rep: jzanutto is on a distinguished road (11)
Re: Problem with turn signals
the dim one is easy - thats just a very bad connection of either the power or ground wire to that light.
They sell a relay that plugs right in place of your original flasher relay, back on the left side behind your seat. That one individual relay will allow the left and right lights to flash independently of each other. So, I think your problem may be with the "creative" wiring job.
jzanutto is offline
View jzanutto's Profile View jzanutto's Gallery Find More Posts by jzanutto
Old 07-27-2008, 3:11 AM
thanks - makes sense. any suggestions on where i can get hold of one? i'm assuming this would replace the flash rate controller...
if it's a bad connection, then it must be somewhere in the wiring loom? i've rejoined the old bypassed wires right where they emerge, between the loom and the orange/blue plastic connector.
ugt33 is offline
Old 07-27-2008, 1:03 PM
someone else already did it.
Flasher question
jzanutto is offline
Old 07-28-2008, 12:00 AM
thanks - i missed that one.
ugt33 is offline
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 11:30 AM.
