2000 SP1--wanting to stall-idle fluctuates
Old 09-29-2008, 10:00 PM
Bike(s): '00 rc51 Mig High Pipes P. comander-'02 rc51 sold-
Rep: solaidrider667 is on a distinguished road (10)
Hey everyone! Hope all is well.... Ok my 00' Rc with 14500 miles recently seems to want to stall at idle ---normally idles @1400 . It started to do this on a hot 'Vegas day @105 deg.(highest temp 227deg at idle normally @ 210@idle) I disconnected my PCIII and put new plugs in her(old plugs showed signs of too rich). Still is happening.It seems to happen worse after steady riding 10 mins or more. At idle it seems to starve for fuel although it smells rich and the idle starts to drop to @ 1000--if you dont blip the throttle it sometimes will cough/pop and stall. You have to hold the throttle slightly open to restart it. No F1 light. Off idle pulls strong and runs fine.Fuel level has no influence on symptoms. Is there a way to test fuel pressure/pressure drop and is there a pressure regulator and if so could the diaphram have a leak(esp when hot)?
Thanks in advance for your knowledge.......
solaidrider667 is offline
View solaidrider667's Profile View solaidrider667's Gallery Find More Posts by solaidrider667
Old 10-01-2008, 6:18 AM
Bike(s): sp1
Rep: wardi10@bigpond is on a distinguished road (10)
Re: 2000 SP1--wanting to stall-idle fluctuates
mate i had the same problem with my sp1 and it WAS the fuel pressure reg,it had a tiny pin hole in it!!i put on a new one (genuine honda part),problem solved!!on my bike it seemed to be the rear cylinder that was fuelling up more so than the front.i put it on the dyno and had it tuned runs like a dream!!!hope this helps you?good luck
wardi10@bigpond is offline
View wardi10@bigpond's Profile View wardi10@bigpond's Gallery Find More Posts by wardi10@bigpond
Old 10-01-2008, 9:04 AM
Bike(s): 2001 RC51
Rep: slammp is on a distinguished road (10)
Take off the power commander and see if the problem goes away.
slammp is offline
View slammp's Profile View slammp's Gallery Find More Posts by slammp
Old 10-01-2008, 9:49 AM
I suspected it could be the fuel pressur regulator. I will replace it and let you know if it helps. I did disconnect the PCIII and I actually gained low rpm power! Now when rollling on the throttle from2000rpm it will lift the front end as where when PCIII connected it would not "hit" untill @ 5ooorpm.
Cheers!!!
Old 12-10-2008, 8:01 PM
Bike(s): 96 600 f3, 98 900rr(stolen), 04 RC51
Rep: Nemesis023 is on a distinguished road (10)
im having the same problems but its got to the point where it wont start now. did the pressure regulator fix your problem?
Nemesis023 is offline
View Nemesis023's Profile View Nemesis023's Gallery Find More Posts by Nemesis023
Old 12-11-2008, 12:40 AM
Bike(s): sp1
my bike was getting harder and harder to start,putting on a new fuel pressure reg did fix my problem.hope this helps you??good luck mate!
Old 12-17-2008, 7:21 PM
do you have a part # or pic of where the FPR is on the 03 rc51?
Old 12-30-2008, 12:56 AM
hey man thanx alot, that did it! the bike is running fine now. a few mor things and she will be in tip top shape. thanx again mate!!
Old 01-30-2009, 12:35 AM
Bike(s): sp1
no worries glad to help.
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 12:47 AM.
