Question for those using K&N air filters....
01-06-2009, 1:08 AM
Bike(s): 04 RC51 Nicky Hayden edition and 99 CBR F4 Posts: 52
Rep:  (10) Rep Power: 1
| Question for those using K&N air filters.... Did anyone not use the cotter pins with the screws?
My bike is stock, do I have to use the "foam air flow restrictors" that go inside the actual filter? The paper says if your bike is stock and you dont put them in then you have to recaliberate your fuel system or something. Thanks |
01-06-2009, 11:04 PM
Bike(s): 2002 RC51 Posts: 52
Rep:  (18) Rep Power: 1
| Re: Question for those using K&N air filters.... Yes, please DO use the cotter pins.
They're there to prevent accidental loosening and ingestion of the bolts into the intake.
K&N says you only need to bend the short end enough to hold the cotter.
I might add they are a pain in the a$$ due to the cramped space in the airbox.
The foam airflow restrictors are there mainly to damp intake noise.
Mine's not stock (I use a Power Commander) so I can't say if any fuel recalibration is needed. |
01-07-2009, 12:55 PM
| Re: Question for those using K&N air filters.... what about using some locktite on the screws? i ve messed with those cotter pins and it's just not working for me. Plus, I'm more afraid of the pins coming loose and getting sucked in than the actual screw. |
01-07-2009, 1:55 PM
Bike(s): rc30 sp1 Age: 44 Posts: 46
Rep:  (41) Rep Power: 0
| Re: Question for those using K&N air filters.... try lock wire. |
01-07-2009, 5:41 PM
| Re: Question for those using K&N air filters.... Quote:
Originally Posted by vamike23 what about using some locktite on the screws? i ve messed with those cotter pins and it's just not working for me. Plus, I'm more afraid of the pins coming loose and getting sucked in than the actual screw. | I wouldn't worry about the cotters being ingested if only the short end is slightly bent to prevent the cotter from falling out.
The long end is supposed to rotate and hit the airbox and prevent further loosening of the bolt.
I agree that lock-tite might be a valid alternative. But there was just that minute element of uncertainty that made me decide on the cotters.
Because those bolts are so close to the intakes, I erred on the side of caution.
I even considered hairpin cotters as a reusable alternative, but again that uncertainty with engine vibration made me reconsider.
I just wasn't willing to take the chance. |
01-07-2009, 8:56 PM
Bike(s): XX, RC51, '08 1000RR LE Posts: 4,540
| Re: Question for those using K&N air filters.... You know you will lose HP with the K&N filters. So why install them? |
01-08-2009, 12:02 AM
| Re: Question for those using K&N air filters.... i'm a little worried about using the locktite, but I ve messed with those pins and i cannot get them in. i use k and n filters because i ve used them in every car and bike I ve ever owned. So it's just what Ive always gone with. |
01-08-2009, 12:06 AM
| Re: Question for those using K&N air filters.... K&N marketing at their best; make people think there are gains when there are none. |
01-08-2009, 2:53 AM
#9 | | WYSIWYG
Bike(s): 2003 954 fireblade Age: 53 Posts: 6,969
Originally Posted by lanbrown K&N marketing at their best; make people think there are gains when there are none. | And their quality of fitment is sh!t as well, compared to all other aftermarket filters.
__________________ I was young and stupid then. I'm old and stupid now. We get too soon old, and too late smart. |
01-08-2009, 12:35 PM
Originally Posted by macca9540 And their quality of fitment is sh!t as well, compared to all other aftermarket filters.  | It only took them 4 or 5 revisions for the 1000RR versions to fit; still didn't perform. The first revision they were too long and wouldn't fit. This just proves that they don't test the products, let alone care if there are any performance gains. |
01-09-2009, 12:03 AM
| Re: Question for those using K&N air filters.... what do you use, bmc? |
01-09-2009, 1:02 AM
| Re: Question for those using K&N air filters.... BMC or DNA. The BMC is similar to the stock and the BMC Race will provide a few HP. The DNA will also provide a few HP. |
01-21-2009, 4:22 PM
#13 |
| Re: Question for those using K&N air filters.... so BMC filters do not use the cotter pins to hold the screw in? please someone who uses them help me out..... |
01-21-2009, 5:42 PM
#14 | | Out Of Many, We Are One
Bike(s): CBR954RR, Hornet CB900F-5, VFR800FI + More Posts: 6,906
| Re: Question for those using K&N air filters.... Sorry I can't help with your problems, but I run stock on all of my bikes. Compared to K&N they flow better, and they also fit better too.
On my MGB and (my ex VR6) Golf on the other hand I have two K&N pankcake filters and also had an induction kit (made my K&N) on the Golf.
They haven't hit the spot for bikes yet.
01-21-2009, 11:52 PM
#15 |
| Re: Question for those using K&N air filters.... i dont have a power commander (....yet) , can i still use the BMC race filters? |
01-22-2009, 7:33 AM
#16 | | Out Of Many, We Are One
| Re: Question for those using K&N air filters.... I believe the bike will adjust to small changes made so I'm sure you probably could, but getting a Power Commander (+ custom map) would make the bike run 100% with the filter and any other changes made - would also increase power slightly if a PC is added.
01-22-2009, 3:52 PM
#17 |
| Re: Question for those using K&N air filters.... def. am going to get a power commander, just am waiting until I catch a deal or can break down and pay the $300 for one. |
01-22-2009, 4:19 PM
#18 | | Out Of Many, We Are One
| Re: Question for those using K&N air filters.... There was a recent discussion about it - I think someone could get one for under $200 - do a search - its bound to be somewhere
01-22-2009, 4:21 PM
#19 | | Out Of Many, We Are One
| Re: Question for those using K&N air filters.... Quote: |
58 Cycle has PC3r for $160 and ToBeFast.com has PC3 usb for $265
| Taken from Jumped in head first with my 929! by Honda4ever
01-23-2009, 8:27 PM
#20 |
| Re: Question for those using K&N air filters.... ok, i ll check those out. thanks a lot..... |
01-24-2009, 4:51 PM
#21 |
Bike(s): 1993 CBR 900rr, 2005 R1, 2003 RC51,2006 Gsxr 1000 Posts: 44
Rep:  (17) Rep Power: 0
Originally Posted by vamike23 ok, i ll check those out. thanks a lot..... | Make sure you get the USB model, not the pc3r. Makes upgrades a lot easier, and you cant get a quickshifter with the 3r. |
01-24-2009, 5:14 PM
#22 |
Bike(s): 06 blk/blk CBR1000RR Age: 25 Posts: 161
Rep:  (20) Rep Power: 2
| Re: Question for those using K&N air filters.... The real question to those that use K&N filters is WHY?  |
01-24-2009, 6:43 PM
#23 | | Out Of Many, We Are One
| Re: Question for those using K&N air filters.... The USB PC3 does make things easier, but the serial PC3 would do the same (you would just have to get a serial to usb converter - cheap on eBay)
The quickshifter would be for those looking for a bit more speed (in changing gears) but if your not looking to race etc, its not really worth it (unless you have money to waste)
Some people like K&Ns as they are washable and they trust that company from past experiences/similar
01-24-2009, 6:51 PM
#24 |
Originally Posted by Twincam
The quickshifter would be for those looking for a bit more speed (in changing gears) but if your not looking to race etc, its not really worth it (unless you have money to waste) |
I havent ridden on the street in at least 6 years, so I wouldnt know anything but track use. As far as a waste of money, the same argument could be made for all these liter bikes on the street.  |
01-24-2009, 7:33 PM
#25 |
| Re: Question for those using K&N air filters.... to put everyone at ease( actually myself at ease, forget you guys  ) i found a BMC filter for cheap so once i receive it next week the k and n will be out the door. Anyone want to buy a k and n thats been used only once?  |
01-24-2009, 7:37 PM
#26 |
| Re: Question for those using K&N air filters.... There is another person on here selling one; not many takers. Why lose power? I suggest you toss it on eBay; they are plenty of suckers there. |
01-24-2009, 9:39 PM
#27 |
| Re: Question for those using K&N air filters.... suckers like me who didnt do their research before buying right? lol. how $160 for a used pcIIIr? what the diff. between pcIII and pcIIIr? |
01-24-2009, 10:42 PM
#28 |
| Re: Question for those using K&N air filters.... The PCIII USB uses USB rather than serial that the r has. You can alos do more with the USB, like the Ignition Module, quick shifter, etc. The USB is the one to get. |
01-24-2009, 11:28 PM
#29 |
| Re: Question for those using K&N air filters.... ok, i thought the pcIIIr also has usb, guess i was mis-informed. you dont think its worth it for the price?thanks |
01-25-2009, 12:25 AM
#30 |
| Re: Question for those using K&N air filters.... You can do ignition adjustments on the 3r also, but I think it is discontinued now. It is not bad for the price, if it is new. You just cant add all the trick toys that you can to the USB. |
